Brass bar inside Water passages in 1948 Straight Eight 8L engine
Hi, I’m repairing a 1948 8L engine, and when cleaning the inner passages in the Block (retiring the Freeze Plugs I found a brass bar of about 4 inches inside.
There were also some steel wires in some passages that were rusted.
Do those cars came with some kind of sacrificial Anode (like Zinc or Magnesium or Bronze) inside of the engine block?
Or maybe these are foundry-cast leftovers that O should
remove
Brass-Bronze bar inside Water Passages in 1948 Straight Eight Oldsmobile
Brass-Bronze bar inside Water Passages in 1948 Straight Eight Oldsmobile below Freeze Plugs
Brass-Bronze bar inside Water Passages in 1948 Straight Eight Oldsmobile. Sacrifical Anode or Cast leftover?
remove
I don't have a lot of experience with water distribution tube engines but I've never seen pieces like those.
Visit the AACA Forums if you haven't already www.forums.aaca.org . There's a lot of water distribution tube engine discussion and expertise there.
I recall another thread on our site recently in which the OP found casting material in the water jacket of his Oldsmobile engine. I believe it was an earlier Oldsmobile engine (371 or 394).
Mystery Metal Lever in Head Coolant Chamber?
There are two reasons your brass bar is not a sacrificial anode:
1. A sacrificial anode metal must be lower in the galvanic series than the protected metal. Brass is higher than iron.
2. A sacrificial anode must be electrically bonded to the protected metal. Your bar is loose.
Great answer VC455, makes total sense.
The part was not pitted, so in this 70 years or so “working” should have. The was a lot of rust (sand-cast leftovers???) in the chambers and the iron wires (that were evenly distributed in the freeze plugs) will be retired, so more flow will run.
Thanks everybody for your answers, will keep posting info about my car.
1965cutlassragtop
Suspension & Handling
January 24th, 2013 04:17 PM
