gas tank for 1937 olds v8
Old June 27th, 2013, 07:05 AM
Wisconsin37olds's Avatar
I'm working with my father-in-law to restore his 1937 Oldmobile. Gas tank ended up being completely rotted out and unrepairable. I'm really at a loss here as to where to find one. Nothing on ebay, tried submitting requests to sketchy parts dealers on the web, etc.
Any thoughts?
Wisconsin37olds is offline
Old June 27th, 2013, 07:58 AM
Tedd Thompson's Avatar
Won't be cheep but if you still have the old rusted out one a good sheet metal shop could probably make one using yours as a model. I have also seen old obsolete tanks sand blasted clean and completely rebuilt with fiberglass resin and mat.... Just a thought ...Tedd
Tedd Thompson is offline
Old June 27th, 2013, 09:19 AM
47 Convertible's Avatar
Tanks Inc.
Any thoughts?
________________________________________________
Have you tried Tanks Inc. http://www.tanksinc.com/index.cfm
I've used them and found them very helpful. Before you call get all of the measurements of the tank, which side it fills from (driver or pass.) and where the filler tube goes into the tank (i.e., toward the forward, middle or rear of the side of the tank).
They didn't have the exact tank for my 47 Olds but by talking to them it turned out a Buick tank they carried was virtually the same. You may find that Buick, Pontiac or Chevrolet would be interchangeable.
Jerry
47 Convertible is offline
Old July 3rd, 2013, 08:17 AM
The_German's Avatar
I am looking for a gas tank on my 56 for more than 2 years already. I am in constant contact with Fusick, who are about to rebuild several different model year tanks.
You may want to contact Dave at Fusick.
The_German is offline
Old July 3rd, 2013, 09:39 AM
jaunty75's Avatar
Deciding to invest in the tooling to make gas tanks for '50s-era models, which are somewhat plentiful, and '30s-era models, which are much more scarce, are two entirely different things. By all means, contact Fusick and everyone else who makes gas tanks. But don't be surprised if you come up empty. You may have to adapt something else or keep looking until you find a serviceable used piece.
jaunty75 is offline
Old July 3rd, 2013, 06:55 PM
stetzie
stetzie's Avatar
Don't know if this will help but, this vendor has tanks for 35-39 chevy's.
Might be something that would work for you.
Location is: 260 Welter Drive, Monticello, IA
Web address: www.tanksinc.com
Phone: 877-596-3842
stetzie
stetzie is offline
Old August 31st, 2019, 08:03 AM
Russ Golesh's Avatar
1937
Any thoughts?
I just had my 1937 Oldsmobile fuel tank sealed with the Renu process. First, they cut holes in the tank and sandblast inside & outside. They then boil it clean. Once dry, they completely coat the inside, outside, & filler neck with a black coating similar to
Por 15. It is then baked at 350 degrees for 4 to 6 hours. Once cured, your tank is hermetically sealed. Don't forget that the filler neck is two pieces screwed together.
The Renu process isn't cheap, but it works!
Russ
Russ Golesh is offline
Old August 31st, 2019, 10:15 PM
Always good to get new information but this post is over 5 years old.... Tedd
jensenracing77
August 28th, 2017 04:47 AM
Ranmat
February 2nd, 2013 09:47 AM
lass4ken
December 21st, 2012 03:16 PM
68vaolds
January 4th, 2011 07:18 AM
cegulley
October 1st, 2010 03:37 PM
Quick Reply: gas tank for 1937 olds v8
