I can't leave anything alone!
Old March 4th, 2012, 07:56 PM
  #41
360scamp's Avatar
...disregard. The 55 was a pile. It has been punched in the back end, "fixed" and repainted. There wasn't a strait panel on it including the roof. The quarters were doing the tri-five dance (tri-five chevy quarters are supposed to be strait and not bulged out. So many of them have been hit in the rear that some resto companies don't realize this and sell new quarters that have the "factory bulge" in them). This 55 olds was whacked pretty good at one point in its life, the whole back of the car is pushed down just slightly and there was a 3/4" gap at the rear of the driver side door but the doors just clicked shut with no problem. It is a good parts car and that is it!
http://seattle.craigslist.org/kit/pts/2880937447.html
I may have a line on 2 56 parts cars about 2 hrs away!
360scamp is offline
Old July 1st, 2012, 10:20 PM
  #42
360scamp's Avatar
Not bad for only half the floors welded in, no front seat, sitting on a folded up blanket, only the ignition wired and parts flopping around when I hit the brakes
http://www.youtube.com/watch?v=Z7V1c6WGCks
360scamp is offline
Old July 2nd, 2012, 08:36 AM
  #43
Collector of Stray 55's
Olds Dad's Avatar
Love that video - first rides are the best - got caught driving my '71 convertible around with no nose, doors roof, decklid - body on frame with radiator support propped up with 2x4's. Went around the block sitting on a milk crate, cop saw me & did a 180 - I screamed into my garage and was closing the door as he pulled into my drive - "Don't think because you put it in there I can't have it towed out" - in the end, given that the car was technically registered & insured, and he was pretty interested in all I was doing (a little politeness and a garage tour goes a long way), he gave me the "next time I see that it better be a car" line, and all was good.
Olds Dad is offline
Old January 18th, 2013, 11:40 AM
  #44
360scamp's Avatar
Picking up a good running 62 394 and tranny for the 56 tomorrow!
The 324 keeps dumping coolant into the crank case and I'm pretty sure it is through the block!
Thanks to this webpage I found it should be a quick swap!
http://webpages.charter.net/dhomstad...me1Source1.htm
360scamp is offline
Old January 20th, 2013, 04:40 PM
  #45
360scamp's Avatar
We went and picked up the 394 yesterday!
pulled off the intake and found this....No carbon build up at all, wiped it with my finger and it didn't even get my finger dirty!
Then pulled the valley pan, looks can be deceiving because there was at least a 1/2" of grease and dirt on the outside of the engine in places.
360scamp is offline
Old January 21st, 2013, 05:36 AM
  #46
Olds Dad's Avatar
Nice find - although the rear springs in your Dodge might have a different opinion!
Olds Dad is offline
Old January 21st, 2013, 07:11 AM
  #47
360scamp's Avatar
Ha, yeah its been lowered a bit.
360scamp is offline
Old January 21st, 2013, 07:39 AM
  #48
okie88's Avatar
What was the 394 in before you got it ? it looks like someone had already gotten rid of the slim jim.
okie88 is offline
Old January 21st, 2013, 07:40 AM
  #49
GM Enthusiast
OLD SKL 69's Avatar
Just came across your thread on the Olds you're working on and I have to say I like the truck too. Looks like a really nice and fun dd.
OLD SKL 69 is offline
Old January 21st, 2013, 08:00 AM
  #50
Tedd Thompson's Avatar
Looks like a Jetaway on the back of it are you sure it's a 394, could it be a 371 out of a 62 or earlier? After 40+ years anything could have been swaped though....Tedd
Tedd Thompson is offline
Old January 21st, 2013, 08:44 AM
  #51
360scamp's Avatar
Told that it came out of a 62 Starfire. It's replacing a 324 and a the slipping 4 speed in my 56 with the help of this page.... http://webpages.charter.net/dhomstad...me1Source1.htm
The tranny being swapped just mskes it that much easier for me.
360scamp is offline
Old January 21st, 2013, 09:16 AM
  #52
59-59-59's Avatar
If it came from a '62, I find it strange why he used a pre '59 power steering pump on it. And the water outlet on the rear passenger side is wrong for '62 - it should have a vacuum operated valve there. Not just an outlet like in the picture. Think only pre '57 had just a water outlet like that
59-59-59 is offline
Old January 21st, 2013, 09:33 AM
  #53
360scamp's Avatar
Soon as I get home I will start running numbers and find out for sure. Either way it is going in my 56.
360scamp is offline
Old January 21st, 2013, 03:41 PM
  #54
360scamp's Avatar
Just checked and all the numbers from the block to the exhaust manifolds are 1962 394. The guy I got it from was also going to put it in a 56 olds so that might explain why the power steering pump, transmission and temp sender have been swapped out. Check out that link I posted, it explains it all there.
360scamp is offline
Old January 22nd, 2013, 07:11 AM
  #55
okie88's Avatar
Sounds like the prior owner saved you lots of work. That's a nice bonus! Keep us posted on how the swap is going.
okie88 is offline
Old January 25th, 2013, 05:43 PM
  #56
360scamp's Avatar
Started the cleaning process.
360scamp is offline
Old February 4th, 2013, 11:05 PM
  #57
360scamp's Avatar
Some more clean up pics...
360scamp is offline
Tedd Thompson
February 21st, 2015 08:43 AM
shamusj
May 29th, 2013 05:15 PM
thomaswatk
December 7th, 2011 02:50 PM
Route66Cutlass
June 28th, 2011 08:56 AM
74 Omega
April 16th, 2009 02:54 PM
Quick Reply: I can't leave anything alone!
