Under Floor Power Brakes - 1955 Olds
#81
wow its been a few years .....but i followed OLdsDad lead ... had a few hic ups but this 2ton rocket now Stops on a dime .
little info ...
First had a guy in N california rebuilt my OE (Sunny) ...had it leak ! took it apart and not ALL SEALS REPLACED .
Frustrated , i followed OldsDad info.
here are pics :
JUNK FROM EBAY
this is off a Malibu ....(dont recall the yr. early? 2010 Sorry )
Re drilled mounting holes
Scarbird Kit
Fit good ... A little fight but was able to use the original paddle . do recall re drilling the Brake Pad to the right to accept the push rod
little info ...
here are pics :
JUNK FROM EBAY
Scarbird Kit
#84
Haven’t been here in a bit but I’m still here! Glad to see this project helped a few.
#85
There should be a solution, at least for the rear, matching the OE 14" wheels:
https://www.wilwood.com/BrakeKits/BrakeKitSearch?flg=14
I'm doing it this year. Thx Olds Dad for this very helpfull thread
#86
Under Floor Power Brake Booster
little info ...
here are pics :
JUNK FROM EBAY
Scarbird Kit
little info ...
here are pics :
JUNK FROM EBAY
Scarbird Kit
It looks as though the brake pedal pushes directly against the master cylinder push rod with NO mechanical multiplication (leverage). In other words a one-to-one brake pedal to master cylinder piston ratio.
How has it worked out? Do you seem to have normal brake "pedal" and function?
Thanks!
1carsick
Brakes/Hydraulic Systems
23
October 2nd, 2012 05:50 PM
russell-t
April 30th, 2011 05:56 AM
47 Convertible
July 14th, 2010 11:39 PM
