Suggestion for disc brake kit 1964 Vista
Old April 24th, 2024, 08:55 PM
1964vistacruiserwagon
mathon's Avatar
I have a 98% original and stock 1964 vista cruiser with drum brakes and 15 inch wheels. Would like to upgrade to a "plain jane" power front disc brake system. Keeping the rear brakes as they are-totally stock. Not interested in drop spindles or suspension mods. Not going to drive it over 65. Any recommended kits?
mathon is offline
Old April 24th, 2024, 09:22 PM
Rocket Renegade!
A rebuilt and optimized factory drum setup is often superior to aftermarket discs done on the cheap.
BangScreech4-4-2 is online now
Old April 25th, 2024, 04:48 AM
I don't know if they offered OE discs in 64 on the Cutlass, or if later model kits will work. If so, using OE parts would be the way to go.
Olds64 is offline
Old April 25th, 2024, 05:00 AM
Rocket Renegade!
Originally Posted by Olds64
I don't know if they offered OE discs in 64 on the Cutlass ...
No, not until '67 and then it would be the complex 4-piston caliper system. I would go with a '69 or later single-piston setup.
But first, I would ask myself some hard questions about my intended use for the car. OP states that it won't see over 65 MPH, which tells me that the factory drums would be just fine as long as they are in good working order.
Old April 25th, 2024, 06:10 AM
The 1969-72 factory single piston caliper disc setup bolts to any 1964-72 A-body car. Use those. Note that if you are reusing the steering arms, the early cars used smaller bolts holding the steering arm to the spindle, so you will need to open those holes up. Original 1964 wheels will not clear the factory brakes. You need disc brake wheels, as used on the 67-up cars. Yes, 14" are available.
joe_padavano is offline
Old April 25th, 2024, 09:17 AM
mathon's Avatar
Thanks for the info!
mathon is offline
Rob64cutlass
Brakes/Hydraulic Systems
29
April 1st, 2022 05:46 AM
Dean Eechaute
November 3rd, 2021 07:19 PM
mortgagepro
September 3rd, 2021 08:12 PM
Wedgewood Rod Shop
January 10th, 2015 08:38 AM
wiseguy58
February 11th, 2010 01:34 PM
Quick Reply: Suggestion for disc brake kit 1964 Vista
