15' Oldsmobile Rally Wheels
I would like to replace the wire spoked hubcaps on my '77 Delta 88 with rally wheels. Does anyone have a suggestion of where I could find some used 15" SSII wheels? Ebay has a few sets available, but they seem to be in rough shape. I like the SSII wheels, but am open to the SSI and SSIIIs as well. If any of you can point me in the right direction, I would appreciate it. I am located in Moorhead, MN 56560 (Fargo area)
Scott
Scott
Create a thread in the parts wanted section. The 15X7 snap on center caps are pretty common wheels. I've got several but to save on shipping it would be good to find a set closer to your part of the country. I believe these are the same 5 on 4 3/4 bolt pattern that was used on the Cutlass/442. John
x2 for Craigslist.
15's are a little harder to find and usually go for more money, make sure they're 15's too. A lot of guys selling them make the mistake of measuring acoss the outside of the rim instead of where the tire sits and it adds an inch, same with width.
The size and other info is stamped inside the rim.
The only difference between the SSII and SSIII wheels are that the the SSII's are painted argent silver and the SSIII's are painted the lower body color of the car.
Send a private message to Jim on here.
He has 2 sets 14" and 15" both with new tires ready to go. I just talked with him earlier today.
follow this link...
https://classicoldsmobile.com/forums...ssiis-vgc.html
follow this link...
costpenn
December 28th, 2013 08:39 AM
TROOP
July 18th, 2011 07:17 PM
