Click Here
Got me some Chevy 15x7" Camaro wheels for my Delta
Old July 18th, 2015, 06:13 PM
Rocket "Scientist"
Dead Reckon's Avatar
Got the set of four for $100, one of 'em has a different serial number than the other 3, but cosmetically they are all the same. Came with two center caps, no tires, they're in pretty nice shape though. Now I just need some white letter tires
Not sure what all the markings mean, I know the 15x7 means they are 15x7's, and I think that JJ is the tire size in the old tire lettering system.
I will get some pics of them on the car when I get some tires, the tires and wheels I have on my car are going under my current project, my 1983 S10.
Dead Reckon is offline
Old July 20th, 2015, 07:33 AM
ioldsnut's Avatar
You may want to do a test fit before you buy tires... I think those are 5X4.75 bolt pattern and I'm not sure, but I think your Olds may be 5X5? Maybe someone else will chime in on this....just didn't want to see you spend money on tires then go "awh s**t"...... Been there...
ioldsnut is offline
Old July 20th, 2015, 08:34 AM
cadillac kevin's Avatar
most deltas are 5x4.75. I have heard some have hd suspension, which included 5x5 bolt pattern
cadillac kevin is offline
Old July 20th, 2015, 09:21 AM
Rocket "Scientist"
The Delta 88's where typically 5x4.75" lug, I know this to be true with my car, the rotors and drums I put on also fit some smaller G/A body cars. My car, like the majority of them, has the tiny 9.5" drums in the back and the 11 and some odd inch discs in the front.
I know the Custom Cruisers from about 1980-1985 had heavy duty suspension as standard, some '86's did, but it was an option only on the 87-89 wagons as far as I could tell. Not sure about the '77-79 Custom Cruisers. Finding brake parts for the '86 Custom Cruiser my family had was annoying, it was an interchange year and still had heavy duty brakes, so we had to get parts for a '85 for whatever reason.
I believe the 98's had the 5x5 lug pattern as standard however, and I'm pretty sure that the '77-79 98's shared a slightly different chassis than the Delta 88's of those years. Unlike the cars up in the 80's, where I am pretty sure the 88's, 98's, and Custom Cruisers shared the same chassis with a few minor differences, mostly in the wagons with heavy duty suspension.
In short, these wheels will fit my car, as will several brake components for much smaller vehicles. Keep in mind though, my car only weighs 3,600lbs. It's not as heavy as some of the more optioned vehicles, it only has a 4bbl 350 SBC and AC as factory options, with that 350 being replaced for a Goodwrench unit back in 1993 as I understand it. The only thing I'm really changing is the tire size, stock size is 215/75R15, I'm going with a 235/70R15.
Old July 20th, 2015, 10:03 AM
ALL 1977-1985 D88s got the small brakes and small bolt pattern wheels EXCEPT cars with HD brakes and suspension. Typically these were police, taxi, and 403 cars.
ALL 1977-1990 B-body wagons got the big brakes and large bolt pattern. There was no "transition year". You needed the big brakes for the 86 because all of them came that way.
All 1977-1984 Ninety Eights got the large brakes and bolt pattern. All 1977-1990 B-body sedans used the same 116" wheelbase chassis and suspension. All 1977-1990 B-body wagons used the same chassis and suspension (which is different from the one on the sedans). All 1977-1984 C-body cars use the same 121" wheelbase chassis. Suspension parts on all of these cars are the same on the front through 1996. Sedans are the same on the back through 1996. Wagons are the same as other wagons on the back through 1996. Yes, the 1994-96 Impala SS suspension parts fit the 1977-1990 cars. The later sedans did use the big brakes and bolt pattern, however.
joe_padavano is offline
Old July 20th, 2015, 06:42 PM
ioldsnut's Avatar
I'm glad that's going to work out for you... I just wasn't sure. My 75 Delta is 5 on 5. I found that out after I bought some Olds wheels that were 4.75 then had to buy adaptors to make it work... Post some pics when your done!
ioldsnut is offline
Old July 20th, 2015, 08:11 PM
Rocket "Scientist"
Will do, gonna be about a month before I can afford tires, gonna get four new ones. Thinking about getting some General Altimax RT's in 235/70R15, but my preferred tire shop does not carry General's.
Also, Joe, I think I'm just gonna start referring to you as a human (I think?) encyclopedia.
But I AM certain that on 1985-1989 Custom Cruisers, the heavy duty brakes where not standard. They came with a package which most dealers opted for, at least that was my understanding of it. Exception mostly being in 1989 when they seemed to throw everything on the cars just to get it out of inventory, most 1988 and pretty much every 1989 Custom Cruiser I've run across was very well optioned. Anyway, to the best of my knowledge, and understanding, the brake changes came about around the time they switched to roller lifters, which was in 1986.
Old July 21st, 2015, 12:35 PM
The Chassis Service Manual begs to differ. My 1986 CSM shows only the big brakes used on the Custom Cruiser. Also, the switch to roller lifters took place in 1985 on the VIN Y motors.
jim larson
April 1st, 2016 02:13 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
TOONLOVESCHERYL
February 17th, 2010 11:40 AM
Kennybill
Ninety-Eight
January 28th, 2009 03:51 AM
Quick Reply: Got me some Chevy 15x7" Camaro wheels for my Delta
