Click Here
Proper way to balance SSII wheels.
Old April 9th, 2010, 12:09 PM
coltsneckbob's Avatar
Is there a special procedure for mounting tires on SSII wheels and in particular for balancing the wheels?
I have heard that to do it properly a spin balancer needs to keep a few tricks in mind?
coltsneckbob is offline
Old April 9th, 2010, 12:36 PM
Lady72nRob71's Avatar
I am pretty sure only the SSII and SSIII's with snap on caps are lug-centric, meaning the hub cannot be used for accurate balancing. The wheel should be secured with the lugs.
Those wheels with bolt on caps have a good fitting hub hole that seems to be okay to use when balancing them hub-centric.
Lady72nRob71 is offline
ATrain1
Non-Olds Engines
June 29th, 2012 12:58 PM
sammieolds
August 10th, 2010 02:49 PM
bigfun64mo
November 11th, 2009 04:59 PM
344870M
August 21st, 2009 08:04 AM
Quick Reply: Proper way to balance SSII wheels.
