Click Here
wheel spacers
Old February 27th, 2013, 01:36 PM
Bluemeanie's Avatar
wheel spacers
My Brother found a great Posi Diff for his 70 Cutlass, but it has been modified and is 3/4 narrower than Stock. He's going to keep his stock SSII wheels, so we can't go wider on the tires.
Can we just use wheel spacers, or is there a reason no to do that???
Anyone know the in's and outs of all this??
Thanks!
Bluemeanie is offline
Old February 27th, 2013, 01:44 PM
csouth's Avatar
3/4" per side our total? Since Olds wheels are lug centric, my only recommendation for peace of mind would be to have a hub centric set made. These would be hub centric to the axle flange and wheel.
http://www.motorsport-tech.com/
csouth is offline
Old February 27th, 2013, 01:46 PM
TripDeuces's Avatar
Your wheel studs probably won't be long enough to engage fully with a spacer. You'd have to get longer wheel studs to make it work if you want to use them. I've also seen wheel spacers that bolt to the axle but have their own studs for the wheel. So basically 5 holes and 5 studs.
Having said that I'll just add I'm not a fan of wheel spacers. It would scare me. Is the rear end 3/4 inch shorter overall or each side? Overall it would not be much of a problem with say using a 1/4 inch spacer. Rule of thumb is you want 1.5x the stud diameter minimum engaged in the lug nut.
TripDeuces is offline
Old February 27th, 2013, 02:03 PM
"Car"mudgeon
GAOldsman's Avatar
I would advise against it by all costs, especially if he plans to romp on it from time to time.
GAOldsman is offline
Old February 27th, 2013, 03:35 PM
Bluemeanie's Avatar
Thanks everyone......trying to find out right now if it's 3/4 overall, or on each side. I've never liked the idea of doing anything like that either. You all just confirmed my "gut" feeling about the whole thing. I'll post again when I have more info/make a decision.
Old February 28th, 2013, 07:47 PM
Bluemeanie's Avatar
Here's the scoop,...This is a Pontiac posi diff out of a 66 GTO. The guy changed the spring bases to be correct for a 67-72 A body, and had it in his 67 Lemans. It's actually maybe 1/4 narrower than the 12 bolt "O" in the Oldsmobile right now. It "should" bolt right in, but now my concern is the yoke is different. The one on the Pontiac is a 27 spline. Anybody know off hand what it is on the 12 bolt and if they are interchangable?
Old February 28th, 2013, 08:58 PM
Do not confuse die cast Chinesiium spacers with properly machined hub-centric spacers. I've run a set of 2" spacers on my dually for nearly a decade now. I got them here:
www.wheeladapter.com
joe_padavano is offline
Daverd
March 10th, 2014 05:46 PM
BCFKody
September 11th, 2012 09:31 PM
hurstman1972
July 25th, 2012 06:01 AM
olds 307 and 403
January 11th, 2012 03:39 PM
truthautomatic
Suspension & Handling
February 17th, 2010 07:58 PM
Quick Reply: wheel spacers
