1969 Cutlass S and 1969 442 Differences
Old December 27th, 2009, 07:36 PM
Olds + Mopar = Happiness
Gearhead442's Avatar
Hey guys i know this seems like a stupid question which i think it is but i want to hear some feedback from Old's nuts like you guys. I just want to know all of the differences between these to car besides the emblems and motor etc. I have spotted many differences myself but would just like to see some of them in a list so i can know "The Official Differences" Sorry if i bore anybody
Gearhead442 is offline
Old December 27th, 2009, 08:50 PM
2blu442's Avatar
OK, here's a few:
Rear bumper with exhaust trumpet cutouts
Exhaust trumpet tips
Rear Bumper brackets with tabs for exhaust
FE II suspension, sway bars and springs
Boxed lower control arms for rear sway bar
Grill Panels
If automatic transmission, it will have a code showing 442 application
You already mentioned the engine and emblems
Others can add to the list.
John
2blu442 is offline
Old December 28th, 2009, 04:19 AM
Also some Cutlass have a chrome stripe around the rear tail light lens and a wide chrome strip on the bottom of the trunk lid covering the trunk key hole[442's have a very thin one at the bottom of the trunk lid] They have a different hood and the air cleaner snorkle is longer and narrower [W learnt me that]
Jamesbo is offline
Old December 28th, 2009, 06:40 AM
You all missed the most important difference - the G-block 400 motor!
Of course, in 1969, the BBO in the A-body used the different motor and frame mounts than the SBO, thus starting a lifetime of motor mount confusion in the Olds community. The base 442 came with bucket seats and a HD 3 speed manual trans with floor shifter (the console was optional. The base Cutlass came with a bench seat and a Saginaw 3 speed manual with column shifter. Of course, both had optional seating and transmissions. Note that the 69 Cutlass was only available with the Jetaway and TH350 automatics, the 442 was only available with the TH400 automatic.
Other differences are the use of fuel return on the non-A/C 442 but no fuel return on the non-A/C Cutlass. The 69 442s got the internal regulator alternator. Lesser Cutlii got the standard external regulator. Standard wheels and tires were also different.
joe_padavano is offline
Old December 28th, 2009, 06:49 AM
Trying to remember member
wmachine's Avatar
The base 442 came with bench seats...........
Oops! Strato buckets were standard. Bench seat was a "deduct cost" option.
wmachine is offline
Old December 28th, 2009, 06:53 AM
Eddie Hansen's Avatar
a nutter
there is a little rocket emblem on the door panels while the cutlass s got just a small s, boxed rear control arms sway bar, I believe the radiator is thicker.
Eddie Hansen is offline
Old December 28th, 2009, 08:11 AM
Yeah, that's what I was trying to write and for some reason had "bench" on my mind. I guess they were just very narrow "benches".
Old December 28th, 2009, 02:35 PM
My apologies
I thought he said "besides the emblems and motors etc."
Jamesbo is offline
Old December 28th, 2009, 04:31 PM
Member
kevdog442's Avatar
hood?
Are you sure the hood is different?
kevdog442 is offline
Old December 28th, 2009, 07:31 PM
Car Junkie
Four Four Tony's Avatar
I believe the S hood and 442 were the same with the seperate bulges. The Supreme has the single plateau style hood.
Four Four Tony is offline
Old December 29th, 2009, 04:56 AM
The Cutty hood says "Oldsmobile on it also.Where as the 442 doesn't say "Oldsmobile" anywhere on the car. It does of course have the rocket emblems.
Jamesbo is offline
Old December 29th, 2009, 05:04 AM
wmachine's Avatar
Good one that is often overlooked.
wmachine is offline
Old December 29th, 2009, 05:05 AM
wmachine's Avatar
Okay, we haven't mentioned this small detail: The "344" in the VIN.
wmachine is offline
Old December 29th, 2009, 07:47 PM
allyolds68's Avatar
Left front of the hood on the Cutlass S has the "Oldsmobile" script, a 442 doesn't have it. I know this is true for 68 & 69, not sure about other years.
allyolds68 is offline
Old December 30th, 2009, 06:33 AM
So did all four doors and wagons, as well as the two door F85 (unless the W-31 package was ordered).
Old December 30th, 2009, 06:34 AM
junior supercar's Avatar
except of course on the Cutlass S W-31 .... if we want to start getting that detailed
other tidbits
the double hump hoods are the same. one has an emblem, one doesn't
442 on the glove box or Cutlass S on the glove box
The chrome stripe on the taillight lens is on F-85 and Supreme
since someone mentioned the VIN, do we have to mention the dataplate also
junior supercar is offline
Old December 30th, 2009, 07:25 AM
stlbluesbrother's Avatar
Lightbulb
Great info guys. Now I'm going to go out and clone a car
On the good side, this allows us to spot potential fraud when someone tries to pass off a Cutlass as a 442 during a sale.
stlbluesbrother is offline
Old December 30th, 2009, 08:44 AM
wmachine's Avatar
I didn't mention the data plate, because many 442s (most, I believe) carry the "336" on the their dataplates!
wmachine is offline
Old December 30th, 2009, 08:47 AM
wmachine's Avatar
With the 442 being a model from '68-'71 thus having identification in the VIN, that particular fraud is a lot more difficult to do.
wmachine is offline
Old December 30th, 2009, 08:24 PM
Thank you all for the replies, they have helped me a great deal.
Old December 31st, 2009, 06:13 AM
4fortwo's Avatar
A few other unlikely changes to a clone:
The front fender gutters under the hood are flat and not crush crimped.
Front sway bar will be .970" vs the Cutlass .937" with a nub on the passenger side.
4fortwo is offline
Old December 31st, 2009, 08:27 AM
very true
Old December 31st, 2009, 10:14 AM
That doesn't apply to the 1969 model year.
Old December 31st, 2009, 03:34 PM
4fortwo's Avatar
Joe, I trust you beyond most, but I have to ask....are you sure?
4fortwo is offline
Old January 1st, 2010, 08:19 AM
Yes. The dimples were designed to allow the front fenders to crush and absorb impact energy in a head-on collision and started with the 1971 model year. This really only applies to 1970 vs. 71-72 front fenders, since these years are interchangeable but the 1970 fenders don't have the dimples whereas the 1971-72 fenders (and the factory replacements) do have the dimples. In any case, it is not a 442 vs. Cutlass distinction.
Old January 3rd, 2010, 10:49 AM
Summerof84's Avatar
How about the pin stripe along the bottom of the dash, or is that a '68 only thing?
Summerof84 is offline
Old January 5th, 2010, 12:03 PM
68 only
Old January 12th, 2010, 02:59 PM
4speedBench's Avatar
Both could be had with Forced Air Induction, I believe.
4speedBench is offline
Old February 2nd, 2020, 11:49 AM
Neil Morrison's Avatar
400ci
You guys are so helpful and knowledgeable about 442,s, but do you know the paint code for engine Bronze ?
Neil Morrison is offline
Old February 2nd, 2020, 11:53 AM
How many different places do you plan to ask this same question? And FYI, most of us just buy pre-mixed Olds bronze paint from places like Bill Hirsch or Supercars or Fusick.
Old February 2nd, 2020, 11:56 AM
  #31
They wont ship paint from USA to Canada, unless its a business account.
We dont have places in Ontario to just go buy it.
yamahondarider
November 26th, 2014 04:51 AM
4speed336
December 10th, 2013 04:36 PM
William O'Hara
November 24th, 2013 10:10 AM
Nor Cal Andy
March 20th, 2011 04:03 PM
texasred
July 31st, 2007 11:33 AM
Quick Reply: 1969 Cutlass S and 1969 442 Differences
