1986 headlights and grille fit into 1987
87/88 were euro style header panels, quite a bit in size for the grills on 81-86 compared to the height, on the euro style. Also composite headlamps compared to halogen bulbs. So I would say no!
Pat
Pat
Not critical to function but if either has fiber optics this may come in to play, no big deal on the park lamp just drill a hole, not sure on how the halogen bulbs work with the fiber optics.
Pat
Pat
If you are referring to the halogen bulbs for the 87/88 style composite head lights.... It is actually a non-issue since the head lights (composite or seal beam) are not part of the fiber optic system.........
Pat
Headlight(low) Headlight (high) and signal. Rear indicators inside on top of center rear window - red indicators for brake/signal.
tmaleck
August 15th, 2021 08:17 AM
oldspackrat
January 20th, 2015 09:16 AM
