Decoding 1964 442 convertible cowl tag
Old January 30th, 2013, 08:13 AM
dmw
dmw's Avatar
Smile Decoding 1964 442 convertible cowl tag
I have a 1964 442 convertible. The cowl tag reads:
OLDSMOBILE DIV. GENERAL MOTORS corp.
3 D LANSING MICHIGAN 2-2
STYLE 64-3267 BODY BF 637
TRIM 967 PAINT CIA
ACC A49 870 5106
THIS CAR IS FINISHED
XXXXX ACRYLIC LACQUER
BODY BY FISHER
Can someone please help me decode this cowl (trim) tag?
The VIN number is: 82 4F014013
I think that the F in the VIN number means that this car was built in Fremont, CA., but the cowl tag says LANSING MICHIGAN .
Can someone please help me.
Thanks,
DMW
dmw is offline
Old January 30th, 2013, 08:53 AM
jaunty75's Avatar
Yes, F is Fremont in the VIN. The body tag tells you where the body was made, and it was shipped to Fremont for assembly. At least, that's my guess.
The VIN for '64 Oldsmobiles was very simple and, except for the assembly plant, doesn't convey any information that you don't already know simply by looking at the car.
8 = 8-cylinder engine
2 = series (Cutlass)
4 = model year 1964
F = Fremont, California assembly plant
XXXXXX = sequential production number at the Fremont plant
1964 was the first year for the 442, and it was an option package available on any '64 F-85 or Cutlass. There is no indication of the fact that it's a 442 in the VIN, and I don't think there's one in the body tag, either. It was just option "BO-9" on the order sheet.
Others will be able to decode the body tag. The "3 D" is the assembly date, which translates to the 4th week (D) of March (3), so that's March 1964. Is there actually a space between the 3 and the D, as usually there wasn't.
It's often recommended that, instead of transcribing the cowl tag here, you simply post a photo of it, as the positions of the numbers relative to letter codes matters, and people often make mistakes in reading it, seeing a "3" as a "B," for example, and things like that.
Your car sounds nice. How about posting some photos of it?
jaunty75 is offline
Old January 30th, 2013, 09:29 AM
Bodies were built in the Fremont plant, not shipped from Lansing.
Last edited by joe_padavano; January 31st, 2013 at 10:22 AM. Reason: Corrected brain fart...
joe_padavano is online now
Old January 30th, 2013, 09:31 AM
jaunty75's Avatar
As Arte Johnson used to say, "verrrrry interesting."
You kind of wonder, though, what would be the point. It's not like changing the VIN plate or cowl tag would make it appear to be a 442. It would be interesting to know if the various options on the cowl tag actually match up with what's on the car, although I'm guessing that, if someone wanted to make the car appear to be original, they could change the car's color, seat type, and so forth, to match what's on the cowl tag.
This would be another reason to see an actual photo of the cowl tag. Those were riveted on, and there might be some visual evidence that the old one was pried off and a new one riveted on.
Of course, I'm assuming the cowl tag was changed. It might have been the VIN plate that was changed. But that's riveted on, too, and so a photo of THAT might be show evidence of tampering.
jaunty75 is offline
Old January 30th, 2013, 09:58 AM
dmw
dmw's Avatar
Smile Decoding 1964 442 cowl tag
Thank you guys for your help.
The car has:
Black Interior/Black Top
4 speed
ragel mist exterior
I will send a photo of the cowl tag later today.
dmw is offline
Old January 30th, 2013, 10:05 AM
dmw
dmw's Avatar
There is a the number "1" casted in the heads on the the front on the driver side and on the rear on the passenger side.
dmw is offline
Old January 30th, 2013, 10:20 AM
dmw
dmw's Avatar
I will send a photo of the car and Cowl tag tonight.
dmw is offline
Old January 30th, 2013, 10:30 AM
jaunty75's Avatar
Looking forward to the photos!
jaunty75 is offline
Old January 30th, 2013, 10:33 AM
jaunty75's Avatar
The "1" is correct for a '64 330 V-8, which is the engine that should be in this car if it's the original engine. Of course, this doesn't tell you if this is THE original engine. But why would somebody change one 330 for another?
http://tech.classicoldsmobile.com/39.shtml
jaunty75 is offline
Old January 30th, 2013, 10:41 AM
"Car"mudgeon
GAOldsman's Avatar
TRIM 967 PAINT CIA
ACC A49 870 5106
BODY BY FISHER
Thanks,
DMW
I can try this evening for you if no one has done so by then.
Bodies were built in the Fremont plant, not shipped from Lansing. This is a disturbing find, as it means that either the VIN tag or the cowl tag has been changed.
Joe the Lansing Mich reference is where headquarters was and if you see this
the BF is the Fremont plant as well. I don't believe it is altered. That is the bad thing about not posting pics, you don't always get a clear picture.
X2
GAOldsman is offline
Old January 30th, 2013, 10:47 AM
Trying to remember member
wmachine's Avatar
Come on guys, you're slipping with the advice here. There is nothing wrong with the trim tag info he posted. All of the Fremont tag blanks say Oldsmobile Div Of General Motors Lansing Michigan" on them because Lansing is the home of Olds. The "BODY BF 637" says the body was made at the Fremont plant.
wmachine is offline
Old January 30th, 2013, 10:49 AM
jaunty75's Avatar
All of this is just a huge indication of the value of posting a photo of the tag and not trying to transcribe it. The positions of words and codes on the tag matter as much as what those words and codes are.
jaunty75 is offline
Old January 30th, 2013, 10:51 AM
jaunty75's Avatar
The LANSING MICHIGAN here is between the 3D and the 2-2, but it is not part of them. And it may not actually be directly between them.
jaunty75 is offline
Old January 30th, 2013, 10:52 AM
wmachine's Avatar
DMW, look at the first section of the Chassis Service Manual for some of the body tag info. Available free of charge at Wild About Cars.
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn.
wmachine is offline
Old January 30th, 2013, 11:37 AM
hurst68olds's Avatar
3 D = March 4th week (1964 assembly date)
2-2 = ?
64 = 1964 model year
3267 = Oldsmobile Cutlass convertible
BF = Fremont, CA
637 = body sequence number (637th Cutlass convertible body at Fremont)
967 = white bucket seat interior
C = white body
1 = white convertible top
A = black wheels (for full wheel covers)
A49 = ?
B70 = ? moldings
5106 = ?
hurst68olds is offline
Old January 30th, 2013, 12:34 PM
TK-65's Avatar
Glad someone came to the rescue in this thread.
TK-65 is offline
Old January 30th, 2013, 12:58 PM
"Car"mudgeon
GAOldsman's Avatar
A49 = Front Seat Belt Retractors (Deluxe) Included Rear
B70 = Dash Pad
Old January 30th, 2013, 04:24 PM
X2
Sorry, you are correct. I replied when I was supposed to be paying attention in a meeting and just skimmed over the first post. I retract my prior post and apologize for the misinformation.
Old January 30th, 2013, 04:33 PM
"Car"mudgeon
GAOldsman's Avatar
It's all good Joe
Interesting fact is the '64 Chebby's that were built in Fremont had Detroit on their plates
Old January 30th, 2013, 05:22 PM
dmw
dmw's Avatar
1964 442 Cowl Tag
I'm sorry but I've tried to load the photo several times but I guess I just don't know how to do it. I'll continue to work to figure it out but it will probably be tomorrow.
dmw is offline
esteo
May 23rd, 2013 08:29 AM
starr88
May 22nd, 2011 08:12 AM
starr88
May 22nd, 2011 06:42 AM
sklbndt
August 26th, 2009 06:35 PM
captn442
March 15th, 2009 07:26 AM
Quick Reply: Decoding 1964 442 convertible cowl tag
