Its a real 442??
Old June 20th, 2007, 04:51 PM
442 Guatemala's Avatar
Question Its a real 442??
Hello Im restoring a 1966 olds 442 with 400 engine. Im triying to decode the VIN number, everithing match, but never says its a 442.
how to know if my car is a real 442? what are the characteristics of a 442?
thanks
Alex
442 Guatemala is offline
Old June 20th, 2007, 08:17 PM
And it won't. Prior to 1968 the 442 package was only an option available on certain Cutlass and F-85 models. The 442 only got a unique VIN between 68 and 71.
By the way, what "matches"? Olds did not start putting VIN derivative stamps on the block, trans, and axle until 1968, so "numbers matching" is somewhat meaningless for a pre-68 Olds.
http://www.442.com/oldsfaq/of442.htm...Authentication (keep scrolling and you'll find a section with year-by-year info)
joe_padavano is offline
Old June 21st, 2007, 03:58 PM
matches
thanks for the information. when I said matching number I mean its a 1966 F-85. Other thing I cant find is if the VIN or ID plate says the engine size. mine has a 400 engine
Old June 23rd, 2007, 06:39 AM
And again, it won't. Before 1972, there was nothing in the VIN or any ID plate that would indicate engine size.
Old June 25th, 2007, 08:56 PM
ReasonOne
Guest
Posts: n/a
GIve me a breakdown of the cowl tag, engine tag and transmission code and I can fill you in on what you might have.
Old July 12th, 2007, 08:18 AM
Chip's Avatar
where is the cowl tag located?
Chip is offline
Old July 12th, 2007, 10:54 PM
Getting There
Ranzan's Avatar
The Cowl tag is located on the drivers side Firewall just beside your master cylinder
Ranzan is offline
boyd_farmer00
November 5th, 2013 08:12 PM
L77F85
October 16th, 2013 08:17 PM
Nickyloves442s
Cars Wanted
June 11th, 2013 09:18 AM
1956OldsDarrin
January 23rd, 2011 12:11 PM
woodie582
July 21st, 2008 05:53 AM
Quick Reply: Its a real 442??
