Looking up block and vehicle numbers
Number crunching galore!
http://wildaboutcarsonline.com/cgi-b...aldisplayed=26
http://wildaboutcarsonline.com/cgi-b...=9970399476565
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and a home page for you online with your own garage where you can show off what you have.
Free to join, free to learn.
With all due respect, the answer is in the third link I just gave you.
JBishop,
There's a small machined pad on the black under the #1 cylinder head that may be obscurred by the power steering pump. The last 5 or 6 (I can't remember off the top of my head) numbers should match the last 5 or 6 of your VIN. First you should check what WMachines had posted above to find out if you even have the correct engine. You can't tell much of anything about "matching numbers" from your cowl tag. You can't even tell it's a 442 from a 68 Lansing cowl tag. The best you can do is look at the build date of your car body (which is about the only thing you didn't post from your cowl tag) and then look to see when the rest of the componants (block, heads, etc) were produced.
BTW there are about a million posts asking the same question. The search function works pretty well here.
That's the casting number. You need to find the number stamped into the block below #1 spark plug. If it's the original block it will read 38 (M or W) 194441
