Swapping steering column column shift to floor on '68
Old February 11th, 2015, 04:41 PM
shamusj's Avatar
I know the '68 columns are one year only due to no key in ignition- are the columns from chevy chevelle or gto the same? Want to make sure I don't screw myself.
Any idea what a decent '68 tilt floor shift steering column sells for?
shamusj is online now
Old February 11th, 2015, 04:48 PM
oldspackrat's Avatar
Not sure if other brands are the same but if it helps I have a non tilt floor shift for a '68 for $100.00 plus shipping.
oldspackrat is offline
Old February 11th, 2015, 05:42 PM
Octania's Avatar
Why not just use the 69-72 column and have two ignition keys?
Octania is offline
Old February 12th, 2015, 08:57 AM
shamusj's Avatar
Non tilt bangs into my knees.
Two ignition keys- I would get so much grief on this site if anyone noticed that set up on my car!
Old February 12th, 2015, 09:43 AM
Octania's Avatar
Yeah, so?
I have seen cars with two shifters, one on the column and one on the floor.
how about a '68 column and '69 dash, and NO place for an ign switch?
Octania is offline
Old February 12th, 2015, 12:53 PM
junior supercar's Avatar
isn't the dash opening for the column smaller on the 68, so a 69 column wouldn't work .... without cutting the metal dash.
now the 68 column on a 69 idea I like.
as for 68 columns from other GM A-bodys, the ***** for the hazard flashers would be different, along with the turn signal arm. I suppose you could swap the olds specific items in place of the others and it would work.
junior supercar is offline
Old April 26th, 2021, 08:35 PM
Paul Judd's Avatar
do you still have column
Paul Judd is offline
Old April 26th, 2021, 09:03 PM
edzolz's Avatar
Do you realize the thread is from 2015?
edzolz is online now
Old April 27th, 2021, 05:35 AM
This happens from time to time, how does a thread from years ago get renewed? When I long on here, I can’t see threads more than a couple days old unless I actually search thru the history. And with the traffic here, that would be a lot of history for a 6 year old thread to show up.
matt69olds is offline
Old April 27th, 2021, 05:45 AM
Because someone new to the site does a search and a long-dead thread pops up. They respond to it without checking the date. Then it gets bumped.
joe_padavano is offline
hvysupreme
February 18th, 2017 12:40 PM
Bitburger
December 30th, 2012 04:49 PM
Alocatelli
December 10th, 2012 07:49 AM
theoldsrocket
January 10th, 2011 08:48 AM
Oldsproject
April 23rd, 2010 04:19 PM
Quick Reply: Swapping steering column column shift to floor on '68
