2001 Aurora A/C problems
Old October 11th, 2010, 04:47 PM
KeithsCustCutlass's Avatar
Exclamation 2001 Aurora A/C problems
So we have an 01 Aurora and the A/C does not blow cold. Have checked the a/c clu fuse and relay. Both are good. Compressor seems to not engage (can't hear it come on when turning a/c on). I had heard that the temp sensor may dislodge, leaking coolant. Where would this be and how do I know for sure whether the compressor is bad or not?
thanks,
Derrick
KeithsCustCutlass is offline
Old October 11th, 2010, 08:51 PM
Boldsmobile's Avatar
Do you have gauges?
Boldsmobile is offline
Old October 12th, 2010, 05:54 AM
Pete has a point. If you have a set of manifold gagues then you should check the pressure in your system. If you don't have a set you can sometimes rent these from the auto parts store. They are pretty simple to hook up.
Olds64 is offline
Old October 12th, 2010, 08:46 AM
i'll check into getting a hold of some
jelardo
Aurora
September 6th, 2011 10:08 AM
easytobedead
November 2nd, 2009 06:03 AM
mikeb
September 14th, 2008 07:28 AM
ajochum
November 30th, 2007 02:40 AM
gregghunter
Aurora
July 21st, 2007 02:13 PM
Quick Reply: 2001 Aurora A/C problems
