Starting Problem
Old August 31st, 2014, 10:23 PM
Cane87's Avatar
Starting Problem
Hello all,
My 2001 Aurora doesn't like to start when the engine is cold. After I get it cranked and turned over, it will want to die again 2-3 times. After that, it runs fine and restarts fine. Until the engine get cold again.
I have an employee who will replace the starter for free. My question is, is it actually the starter, or will I be wasting money on an unneeded part?
Thanks in advance.
Cane87 is offline
Old September 1st, 2014, 05:18 AM
Lansing built
1970cs's Avatar
I guess my first question would be 3.5 or 4.0 engine? Second would be, does it crank but will not start or no crank? Third how many miles?
Pat
1970cs is offline
Old September 4th, 2014, 11:06 PM
Cane87's Avatar
Pat
1. 3.5.
2. Cranks but will not start. Or, starts but then shuts off. Usually stays on after the fourth restart. The problem only occurs when it's cold. When it's warm, it starts and runs like new.
3. 152K.
Cane87 is offline
Old September 5th, 2014, 09:29 AM
Jetstarjim's Avatar
I wouldn't lean to much towards the starter. If you have a "service engine soon" light on, it will help point you in the right direction. If I were to guess, I would consider weak fuel pressure, or consider the failure of an engine management sensor. I had one with a faulty coolant sensor that would "trick" the computer into thinking ( I know, they don't really think, lol!) the engine was at operating temp, and didn't like to run cold.
Jetstarjim is offline
Old September 5th, 2014, 05:10 PM
Lansing built
1970cs's Avatar
I would guess that Jim's idea is what I was thinking also! Fuel pressure regulator is what my guess but you need to measure the fuel pressure with a gauge to determine if that is it.
Pat
1970cs is offline
bccsrc
November 29th, 2011 11:08 PM
The Stickman
October 25th, 2009 07:04 PM
Maverick
June 4th, 2008 07:46 AM
bjtstarfire
October 29th, 2007 06:51 PM
Classic Cutlass
February 15th, 2007 04:54 AM
Quick Reply: Starting Problem
