Window help
Old May 13th, 2007, 08:56 AM
d14u2nv7's Avatar
Window help
I am pretty sure i have an electrical problem in the boot of the driver's door but i am having a hard time getting the door off. i might have to remove the fender. any advice on this would be great. Also wiring diagrams would also be appreciated. i have had this problem on my 95 for a while where the windows were intermittent and would have to open and shut the door to keep them working. thanks again.
d14u2nv7 is offline
Old May 13th, 2007, 01:09 PM
d14u2nv7's Avatar
just as suspected. pulled the inside of the door off and disconnected all the clips. then pulled the wiring harness through the hole where the boot is. this was with the door on the car still. when i slid the boot down there were 5 wires that were completely seperated and 3 that were cracked and on their way to breaking.
d14u2nv7 is offline
Old May 28th, 2007, 09:37 PM
yestertech
Guest
Posts: n/a
I have the same problem on a '95 - and one wire fell deep in and was hard to retrieve. This may be pretty common. Many other wire jackets were cracked there.
wyteon
Vista Cruiser & Wagons
November 30th, 2018 11:33 AM
f-85
January 16th, 2012 06:10 AM
jugdish
August 18th, 2011 09:57 AM
leepear
April 22nd, 2011 02:22 PM
MJAKS462
April 15th, 2010 02:34 PM
Quick Reply: Window help
