394 performance parts
Old April 20th, 2024, 11:08 AM
Mikeyt
Mikeyt's Avatar
Going to look at, hopefully make a deal, on a 62 98 with a 394.
The plan is to run it as is and fix the small things for now.
I know myself though and once that's done I'll be looking for something else to do.
More power is always nice.
Is there any aftermarket performance support for these engines?
Intake manifold, headers, etc?
Google can't seem to find any.
Mikeyt is offline
Old April 20th, 2024, 11:33 AM
Proud Viet Nam Veteran
redoldsman's Avatar
About the only things you may find are used and are on places like ebay.
redoldsman is online now
Old April 20th, 2024, 12:32 PM
Run to Rund's Avatar
Isky still has cams, lifters, etc,
Run to Rund is offline
Old April 20th, 2024, 12:47 PM
Mikeyt
Mikeyt's Avatar
I guess keeping it stock is my only option.
I guess that's a good thing for my wallet. Lol
Mikeyt is offline
Old April 20th, 2024, 12:58 PM
Sugar Bear's Avatar
Stock but tuned should give more than adequate performance. I'm guessing the 98's were all High Compression 4 barrel engines... anyone???
Dual exhaust would be nice.
Sugar Bear is online now
Old April 20th, 2024, 06:53 PM
Phantom Phixer
Charlie Jones's Avatar
yes, they all were .
There are a few speed equipment manufacturers making stuff for 394's.
Besides Isky, Camcraft makes several 394 grinds,
.Automotive Performance Camshaft Production Manufacturer | Camcraft Cams
Offenhauser still makes new tri-carb and dual quad manifolds.
They are available through Exeter Auto Supply.
EAS - Offenhauser Catalog (exeterautosupply.com)
Charlie Jones is offline
Old April 20th, 2024, 06:57 PM
Oldsdruid
rocketraider's Avatar
The SkyRocket 394 in the Ninety Eight was rated 330 horsepower. It would move a Ninety Eight out right smartly.
The 59-64 394 was the engine of choice for Gasser drag racing classes and there was tons of speed equipment made for them until the Chrysler 426 Street and Race Hemis appeared in 1964. The low-compression 2 barrel versions worked quite well with a GMC 71-series supercharger perched on top of them.
rocketraider is online now
Old April 21st, 2024, 03:17 PM
Mikeyt
Mikeyt's Avatar
She definitely needs a tune.
Runs really rich and Trans shifts way too early.
Dual exhaust is first. Gotta chop off that single glass pack dumped at the axle. Sounds like a beat up farm truck right now.
Thanks for replying
Mikeyt is offline
Old April 21st, 2024, 03:21 PM
Mikeyt
Mikeyt's Avatar
Once I get her running right I'll add some performance parts.
tri carb would be cool
Mikeyt is offline
Old April 21st, 2024, 03:36 PM
Mikeyt
Mikeyt's Avatar
Motor purrs just as smooth but she shifts too quick and sounds like a farm truck but I think I'm in love.
Mikeyt is offline
Old April 21st, 2024, 05:18 PM
Sugar Bear's Avatar
Very nice looking ride!!!
Old April 21st, 2024, 06:17 PM
Phantom Phixer
If you don't already have one, an Oldsmobile shop manual is a very good investment.
These are the books Olds mechanics used at the dealership.
In 1962 Olds published a supplement to their 1961 Shop Manual.
You will need both books if you have a '62.
Among the many other things you will find in the shop manual, are instructions on how to adjust the transmission throttle linkage.
Printed original copies are preferred.
1961 oldsmobile shop manual 1962 for sale | eBay
There is a special adjustment tool that has to be used. They are available from JASWEST.
JASWEST - Product Catalog
A good dual exhaust system is highly recommended.
Luckily, the exhaust manifolds were the same in '62 for single or dual exhaust.
All you will need are mufflers and pipes. They are available from Waldron's.
Waldron's Exhaust – Car exhaust, truck exhaust, exhaust pipes, mufflers (waldronexhaust.com)
Old April 21st, 2024, 07:34 PM
Oldsdruid
See you're in NC. Whereabouts?
Old April 21st, 2024, 10:08 PM
Mikeyt
Mikeyt's Avatar
Thank you
Mikeyt is offline
Old April 21st, 2024, 10:09 PM
Mikeyt
Mikeyt's Avatar
Great info Thanks!
Just ordered both manuals. Man that's gonna be a big help!
Mikeyt is offline
Old April 21st, 2024, 10:10 PM
Mikeyt
Mikeyt's Avatar
Eastern NC, Beulaville
Mikeyt is offline
Old April 23rd, 2024, 07:20 AM
Oldsfan's Avatar
There may not be anything wrong with that transmission. It is what they called a "Slim-Jim." They are a different animal. People tend to say unkind things about them. Damper plate bolted to the flywheel like a manual transmission. No external torque converter - it has a fluid coupling (that fills and empties) inside the trans behind the front pump. It will not shift like Turbo HydraMatic. Adjustment and fluid level are important.
Oldsfan is offline
Old April 23rd, 2024, 08:11 AM
Mikeyt
Mikeyt's Avatar
It just shifts way too early no matter how much throttle you give it.
Mikeyt is offline
Old April 23rd, 2024, 01:11 PM
Phantom Phixer
Make sure the linkage between the carb and the transmission is connected properly.
Old April 23rd, 2024, 01:22 PM
Kjr442
kjr442's Avatar
394
I do know someone selling a bunch of 394 parts. One thing I thought was coo is the two 4 bbl intake.
kjr442 is offline
Mikeyt
Mikeyt's Avatar
Will do.
Thanks again Charlie
Mikeyt is offline
FTolliver
March 19th, 2023 06:49 AM
FTolliver
July 2nd, 2022 04:24 PM
INTRUDER
December 19th, 2019 01:36 PM
jrok420
July 22nd, 2011 01:21 PM
44TEETWO
January 14th, 2009 07:04 PM
Quick Reply: 394 performance parts
