Another project nearing completion
Old April 6th, 2024, 06:02 PM
72455's Avatar
After about 2 months of putting it off, I'd finally had enough of the intake manifold gasket leak on my '72 Supreme.
So I buckled down and ordered a set of gaskets and started the teardown this past Thursday.
My buddy came over that afternoon and helped me with getting the gaskets on and setting the intake on. (Helpful tip: make sure you remove the rags before you set the intake on...we almost missed that important step...lol) For those that want to know, we used Permatex Ultra Grey around the water jackets and as well as the front and rear of the intake, and Indian head on the gaskets themselves.
Everything is all back together as of yesterday, and tomorrow we're dropping in the distributor and setting the timing.
Anxious to hit the key and call it done!
72455 is online now
Old April 6th, 2024, 06:27 PM
2blu442's Avatar
Nice to see progress! Glad you have a local car buddy to give you a hand when needed!
2blu442 is offline
Old April 6th, 2024, 06:42 PM
Setting that intake back on is a 2 person job for sure.
Fun71 is offline
Old April 6th, 2024, 06:44 PM
72455's Avatar
It's a Performer, so not so much the weight as the precision.
72455 is online now
Old April 6th, 2024, 06:48 PM
Ah, that shaves off 30+ pounds.
Fun71 is offline
Old April 6th, 2024, 07:07 PM
72455's Avatar
So I've read...I couldn't imagine taking it off by myself, let alone putting it back on if it were cast iron...jeez...lol
72455 is online now
Old April 6th, 2024, 07:59 PM
Yeah, my original iron 350 manifold tipped me over into the engine bay when I was leaning over the fender putting it back on by myself. That was in high school when I was a bit lighter than I am now, but a BBO manifold would still tip me over.
Fun71 is offline
Old April 9th, 2024, 04:44 AM
Looks like it is nice and clean inside.
Greg Rogers is offline
Old April 9th, 2024, 06:10 PM
72455's Avatar
So my buddy Mike came over Wednesday and we dropped the distributor in and set the timing. Fired it up and still had an oil leak. We saw it was coming from the passenger side valve cover gasket. I swapped it out tonight and no joy.. still have a leak from somewhere. It's not the valve cover gasket...that's bone dry. My only guess is the oil filter housing gasket, so I'm gonna swap that out next. Arg...just when I thought it was good.
72455 is online now
Old April 9th, 2024, 07:50 PM
They sell it at nearly every automotive parts/supply store; or, continue guessing.
Vintage Chief is offline
Old April 9th, 2024, 07:53 PM
72455's Avatar
I hear ya Norm, but the problem is, I wouldn't be able to see the source even if I did use that.
72455 is online now
Old April 9th, 2024, 07:56 PM
Sorry, 100% disagree. Load up your parts cannon.
Old April 23rd, 2024, 03:01 PM
72455's Avatar
So turns out there was no leak. It was residual burn off that had soaked into the heat shield I wrapped around the header. Once I removed the heat shield, I was good
72455 is online now
Old April 23rd, 2024, 03:38 PM
Ha. There ya go.
tgilligan
November 19th, 2018 07:57 PM
RROLDSX
August 16th, 2017 03:05 PM
mike1976
September 12th, 2016 02:07 PM
Lars
Non-Olds Engines
February 15th, 2015 05:34 AM
808olds
October 26th, 2010 03:59 PM
Quick Reply: Another project nearing completion
