45 vs. 39 cam bank angle question (oh boy)
Old April 29th, 2009, 12:50 PM
Registered car nut
nonhog's Avatar
Most of you old time olds guys are sick of this stuff. I have found all sorts of info on how to figure what you've got. Great ! We dont need to re do that subject.
question #1) which is best to have for ease of getting parts ?
question #2) Can you find parts for both ? Limited ?
question #3) If you had the hard to find parts one, would you build it ?
opinions wanted - facts needed
nonhog is offline
Old April 29th, 2009, 01:33 PM
39 deg is much more common (all 68-90 motors)
Yes
Already have.
By the way, you do realize there's a per-question charge, right?
joe_padavano is online now
Old May 4th, 2009, 06:17 PM
Purveyor of Polyurethane
ijasond's Avatar
I just did a 66 with the 45 bank angle. The only thing that had a limited selection were the camshafts. Most of the cams I found were for the 39 or they had no idea if it was for the 39 or the 45. After speaking with a couple different people, I decided to go ahead and order one through mondello. I'm told it's an engle part, but it came in a blank white box. They were the only ones that seemed to be familiar with the difference. With the knowledge compiled on this forum, you should be able to find any and everything you need.... As long as it's not a rear bumper for a 66 88.
ijasond is offline
Old May 10th, 2009, 12:57 AM
geckonz08's Avatar
Every part I have had trouble finding has entailed just a little more reseach for availability. Even the .921 lifters if you have them --just a wee bit more pricey but negligible on an overall build cost.
geckonz08 is offline
Old August 15th, 2009, 08:54 PM
hotrodpc's Avatar
I know this is an older thread, but for anyone who finds it, Comp Cams also has the 45 degree cams. I should have saved or bookmarked the online catolog I seen them in, but it specifically listed 45 degree Olds 425 camshafts. So Comp Cams is also aware and I have also been told, they have the blanks too and will custom grind any 45 degree cam you want to your specs, so if you see a 39 degree cam spec that you like, contact Comp Cams and tell them to grind it to match the 39 degree cam youi like.
hotrodpc is offline
Old August 25th, 2009, 03:37 AM
oldstrio's Avatar
SAME WITH BULLET / ULTRADYNE OUT OF MEMPHIS ALSO
oldstrio is offline
Old August 25th, 2009, 07:07 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Capital should have your bumper.
http://www.capitalautoparts.com/
J-(Chicago) is offline
Old August 25th, 2009, 10:38 AM
ijasond's Avatar
If they have it, you are definitely going on my Christmas list. They aren't too far from me either.
ijasond is offline
Old August 25th, 2009, 03:59 PM
ijasond's Avatar
well, I called him, he said that was a really old part number but he would check and see if they had it. He also said he would call me back to let me know, which hasn't happened yet.
ijasond is offline
lemoldsnut
Tech Editor's Desk
June 29th, 2015 10:26 PM
jhoppeolds
August 21st, 2014 05:26 PM
Octania
June 1st, 2014 12:21 PM
Old Olds Fan
October 2nd, 2013 05:19 AM
raymondh36965
March 24th, 2010 06:10 AM
Quick Reply: 45 vs. 39 cam bank angle question (oh boy)
