Looking for source for 425 45 degree bank angle camshaft
Old August 5th, 2014, 09:52 PM
jhoppeolds's Avatar
Currently doing a stock rebuild a '65 425 Starfire engine. Is there a source for a stock grind camshaft? If not, what is the overall availability of the early 45 degree cams?
jhoppeolds is offline
Old August 5th, 2014, 11:18 PM
Engine Builder
Smitty275's Avatar
Readily available from most cam companies. I have one on the shelf for sale. Unfortunately I'm not going to be in the shop for several days.
Smitty275 is offline
Old August 6th, 2014, 04:32 AM
cutlassefi's Avatar
Or I offer custom grinds as well. Thanks.
cutlassefi is offline
Old August 6th, 2014, 11:27 AM
edzolz's Avatar
I have a new in box Erson TQ 20. 45 degree cam. $75 plus the ride.
edzolz is offline
Old August 6th, 2014, 01:17 PM
Run to Rund's Avatar
Comp Cams can grind them also.
Run to Rund is offline
Old August 12th, 2014, 04:34 AM
The Flash's Avatar
whats a good size cam for something above stock?
my engine is at the re builder and cam was worn
1966 425
thanks
The Flash is offline
Old August 12th, 2014, 06:09 AM
cutlassefi's Avatar
Erson MP2 would be perfect for a better that stock replacement.
Old August 12th, 2014, 07:26 AM
The Flash's Avatar
ill look in to that
thanks
Old August 12th, 2014, 08:12 AM
The Flash's Avatar
any ideas where i can find one of these cams?
PBM performance has it listed but there checkout is not working
before i pickup the phone i want to see if there are any other options
thanks
Old August 12th, 2014, 11:04 AM
cutlassefi's Avatar
Yes any Erson dealer can get you that cam.
Old August 12th, 2014, 04:02 PM
L69
L69's Avatar
Mark from cutlassefi. Knowledgeable and honest
L69 is offline
Old August 14th, 2014, 06:20 AM
The Flash's Avatar
just to double check, this cam is very big compared to stock also the discription does not say its for a 45 degree 425 engine
Old August 21st, 2014, 10:32 AM
jhoppeolds's Avatar
I was looking at the Erson M/P1 as a suitable replacement for the stocker in my '65 Starfire 425, but the Erson catalog only shows 39 degree cams and numerous attempts to call them to see about any of their cams being ground in a 45 degree bank angle only resulted in a busy signal (even after hours). Seems like the phone is off the hook. Also called Comp Cams and was told they are currently not offering any cams in a 45 degree angle due to the lack of blanks.
Old August 21st, 2014, 10:57 AM
The Flash's Avatar
after measuring turns out i have a 45 degree engine have you heard anything about camcraftcams com?
Old August 21st, 2014, 11:21 AM
Beer Connoisseur
70cutty's Avatar
You guys should contact Mark - Cutlassefi for all your cam questions and needs. Great guy to deal with, he has helped many with their cams and more.
70cutty is offline
Old August 21st, 2014, 11:28 AM
The Flash's Avatar
i spoke to the guy at camcraft and he seamed knowledgeable about the Olds engine he even showed me how to check to verify it was a 45 degree engine.
On there web site it states that it should be verified as well as lifter diameter and that was new to me so that's why i was asking.
Old August 21st, 2014, 05:26 PM
cutlassefi's Avatar
Once in a blue moon you'll find an Olds block that'll have both oddities, i.e. a 45 degree bank angle AND a .921 lifter bore. So if it has a .842 lifter bore it most likely will be a 45 degree block and vice versa.
lemoldsnut
Tech Editor's Desk
June 29th, 2015 10:26 PM
Octania
June 1st, 2014 12:21 PM
Old Olds Fan
October 2nd, 2013 05:19 AM
raymondh36965
March 24th, 2010 06:10 AM
nonhog
August 25th, 2009 03:59 PM
Quick Reply: Looking for source for 425 45 degree bank angle camshaft
