Buning Oil
Buning Oil
I have a 70 BBO that I had professionally rebuilt about 7 years ago. It was never started and run until just recently. It starts right, up runs smooth and seems to have plenty of power but it smokes from the left tailpipe at startup. I'm guessing that it's one, or more, leaking valve seals. Short of tearing it down, are there any tricks to help solve the problem?
Change the spark plugs and during the spark plug R&R perform a compression test - both wet & dry and determine any deltas in compression test between wet & dry compression numbers.
You don't state exactly what was done during the rebuild seven years ago. Did they replace pistons & rings? Heck the rings may not even be seated yet. The valves may not even be completely seated. I'm suspecting if the rebuild was professionally done and the vehicle runs fine, it's most likely a ton of water moisture in the system burning up each time you start-up; but, it's a crap-shoot at this point. I wouldn't necessarily suspect valve seals straight off. Whenever a rebuilt is accomplished (depending on what was done), you should have a period of 'burn-in' in which the engine is run for select number of miles w/in select framework of speed variations.
I certainly wouldn't consider a tear-down until you get some compression numbers and change out the plugs, fuel & oil firstly.
If you determine that it is indeed the valve guide seals leaking then you don't have to tear the engine apart to replace them. You can put compressed air in the cylinder at TDC to keep the valves from dropping when you remove the valve keepers. Better yet, feed nylon rope into the cylinder through the spark plug hole near TDC and compress the rope against the valves by rotating the engine with a breaker bar. Then you can remove the springs and replace the valve guide seals.
I should have been more clear in my description. Engine was built 7 years ago from the bare block up. Everything in it is new. It was never installed in a car and has been on am engine stand the whole time. It was just installed in a car that that I am redoing so everything, fuel and fuel tank oil, water, is fresh. It is smoking blue smoke from left exhaust at startup, nothing from the right side. It doesn't seem to smoke after that. From the blue color and the smell, I am assuming oil but I could be wrong. It has been through the cam break in process but beyond that, has been run at idle only. Maybe my complaint is premature and it just needs some miles on it?
