cam choices. not so much daily drive as rice killer
Old December 21st, 2009, 07:04 PM
procharged70cutlass's Avatar
i have a 70 cutlass supreme. 455 +.030 N crank, C heads. l2323 pistons. 9.5 cr. 200r4 trans with 2500 stall , 4.10 gears with 28 inch tire. looking to build as much motor as possible to stomp some rice. im not too worried about much as long as it runs good, lives long time, and kicks some ***.
i was looking at some mondello cams but i dont know what other would be good. i was told that i could use my bbc roller lifters on the olds. is this true
procharged70cutlass is offline
Old December 21st, 2009, 08:03 PM
captjim's Avatar
The venerable Engle 20-22 (226/230) or a Voodoo 60803 (227/233) would both work well in a hot street 468, IMO. Mark (cutlassefi) would be happy to grind one for you. He really loves Engle cams!! I personally would not mix and match lifters, just get a new set with your new cam and avoid the headaches.
captjim is offline
bojanglez403
January 22nd, 2015 05:13 AM
Olds1971
September 28th, 2012 12:08 PM
ah64pilot
Suspension & Handling
53
September 11th, 2012 06:24 PM
ihengineer76
June 4th, 2012 06:23 PM
jpc647
April 7th, 2011 04:26 PM
Quick Reply: cam choices. not so much daily drive as rice killer
