engine rebuild costs
Old May 6th, 2008, 02:21 PM
68Tom's Avatar
Hi--
I have a '68 442 with the original 400 engine--numbers matching block & carb--that I'm looking to get rebuilt. Maintaining a stock-like output and parts, what should I expect to pay for this?
Now, I'm sure the region I'm in will dictate a slightly higher cost (Northeast--CT, NY, etc), but a ballpark figure would be nice. I was told somewhere between $3500-4500. All the machining will be done in-house at the place that quoted me.
Also, I've been looking at the price of rebuild kits ($1000-1200). How is the quality of parts in these? And if you had a place to recommend, which would you use?
68Tom is offline
Old May 6th, 2008, 04:22 PM
442Harv's Avatar
Depending on what you need done, but I live in Nor Cal, just put together a 455 about a year ago, and I had about $2000-2500,for machine work and parts, and I put it together. A 400 will cost more than a 455. Mine was cleaned and checked, bored, and two cylinders sleeved, head job, no new valves or springs, just ground valves, turn crank and balance engine,and decked the block, new cam , pistons bearings oil pump gaskets
442Harv is offline
Old May 6th, 2008, 06:04 PM
68conv455's Avatar
Tom....I feel your pain (from new haven, ct area). I bought a 455 core for rebuild and was shocked at the 3000 - 4000 price range people wanted (top to bottom). I ended up buying a second (good running low milage 455) to drop in as-is for about 1G.
I also respect your desire to keep it numbers matching. I'd do the same. Sometimes you just have to grit your teeth and write the check.
68conv455 is offline
Old May 6th, 2008, 06:21 PM
The_Jeremiah's Avatar
I just rebuilt my olds 350, doing all the machine work myself and getting a 10 percent discount on most of my parts, i spent around 1500. I still have a carb to buy, so really, around 1850 or so.
The_Jeremiah is offline
Old May 6th, 2008, 08:26 PM
59-59-59's Avatar
This should get you mad - I recently completed a 394 Olds and I got to thinking...for the same price I spent to rebuild this, I COULD OF GOTTEN 3 350 CHEVROLETS DELIVERED BRAND NEW TO MY DOORSTEP WITH A 3 YEAR WARRANTY. And now I am looking for another 394 project - I have problems, or maybe a sickness
59-59-59 is offline
Old May 6th, 2008, 09:33 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
59-59-59, have you ever gotten parts from egge.com?
I'm thinking about doing my Mercury flathead, and was wondering if their stuff was really nice.
J-(Chicago) is offline
Old May 6th, 2008, 10:00 PM
59-59-59's Avatar
Funny that you mention Egge, because I was thinking of ordering some stuff out of their catalog. I got sent a catalog from Egge and to my surprise they dont even have the ***** to list prices! I went with a place in Texas called Terrill Machine, which advertizes in Hemmings, WITH their prices listed. The only things I needed were the piston/ring set, timing set and bearing set - practicaly everything else I needed I have NOS. I was very happy with them, and have been a repeat customer. Egge did have a variety of new Edelbrock and Navarro intakes and heads for the flatheads, along with different piston sets with crazy oversizes like +0.080 with varied compression ratios.
59-59-59 is offline
Old May 7th, 2008, 09:49 AM
68Tom's Avatar
Thanks guys. How about the rebuild kit? Are they good? Any better than the other?
68Tom is offline
Old May 7th, 2008, 04:05 PM
442Harv's Avatar
Most kits are just the parts. Not sure what the kit contains, but the Olds are usally not like a Chevy, with block and cranks. What does the kit have you are looking at?
442Harv is offline
projectheaven
October 9th, 2012 03:33 PM
auto_editor
July 28th, 2011 08:20 AM
Moses
November 21st, 2010 04:31 PM
mhood
September 16th, 2010 06:37 PM
import extermination
May 12th, 2009 10:37 AM
Quick Reply: engine rebuild costs
