Location for over flow bottle
Old August 22nd, 2012, 06:34 AM
1971 442 convert
1971 442 convert's Avatar
Just wondered where the correct location was for an over flow bottle for a 1971 442 455. Where does it go ? Any pics ?
Thanks,
Roger
1971 442 convert is offline
Old August 22nd, 2012, 02:08 PM
2blu442's Avatar
It's on the passengers side, check with "Allan R" to see if he has a drawing of the correct location and bracket. Do you have a factory setup or repop unit?
John
2blu442 is offline
Old August 22nd, 2012, 07:23 PM
1971 442 convert
There has never been a over flow bottle just a hose. Was looking at the re pops and not sure as my washer bottle is right there. Meanwhile I have hooked up my washer bottle as the over flow as I am trying to keep a little more coolant in my rad to see if it helps with my over heating after highway speeds when I sit at idle.
Old August 22nd, 2012, 07:50 PM
stevengerard's Avatar
not sure you should be looking at an overflow tank as help to an overheating problem. You can go to wildaboutcars.com and download the assembly manual for 71 and that will show you where they went. I thought by 71 the 455 came with them but maybe that was 72.
Is your fan working, if it is a clutch fan it may not be engaging enough.
stevengerard is offline
jpc647
November 2nd, 2014 03:40 PM
Bernhard
March 8th, 2013 08:37 PM
71POWER
October 6th, 2012 08:29 AM
Sid
September 27th, 2010 07:55 AM
slowolds
Hurst/Olds
June 15th, 2010 05:09 PM
Quick Reply: Location for over flow bottle
