Radiator,pushing water out over flow
Old September 27th, 2010, 06:13 AM
Sid
Sid's Avatar
I have a 57 olds that the top of the radiator started to leak, I pulled the radiator and had it gone thru now when it is reinstalled it pushes water out the over flow. I have 15 pound cap. With out the cap on the water is moving real well over the tubes. I would think it was the cap, but is not that old I also replaced the theromstat . What do you think?
SID
Sid is offline
Old September 27th, 2010, 07:27 AM
Oldsdruid
rocketraider's Avatar
Are you filling the radiator to the top of the filler neck, or are you leaving a couple inches airspace for expansion? If it's overfilled it will puke out coolant till it finds the level it wants, usually 1-2 inches below the neck.
If you know a shop with a cooling system test kit they should be able to test the pressure cap, but if cap was performing properly before a radiator rebuild ought not have affected it.
rocketraider is offline
Old September 27th, 2010, 07:55 AM
citcapp's Avatar
Nice looking 57, I installed an after market overflow tube style tank. Now I don't have that problem anymore. Otherwise Rocketradier is correct leave room for expansion
citcapp is offline
Bernhard
March 8th, 2013 08:37 PM
1971 442 convert
August 22nd, 2012 07:50 PM
ELECMAN
January 23rd, 2011 10:11 AM
AZ442
July 16th, 2010 05:34 AM
slowolds
Hurst/Olds
June 15th, 2010 05:09 PM
Quick Reply: Radiator,pushing water out over flow
