New engine vibrates
New engine vibrates
I had a guy in St Charles Mo build my #s matching W30 4 speed engine.
When installing the distributor it was installed 180° out.
It ovalled my Gardner muffler.
The engine vibrates. Rotating assembly was balanced.
What would cause the fast vibration.
would the backfire from the distributor cause it.
Lost. He return the job vibrating running bad.
took it to supposedly a reliable shop in union mo. The nutbag dynoed the engine it let loose. Balance job off 16 grams
Possibly totaled the block.
find out soon
St Charles guy is innocent of any wrong doing. Engine wasnt balanced
find out soon
If you got your car back and the engine vibrates and suffers from NVH, then no doubt the guy you took it to was a jabroni. I'd put a timing light on it and make sure the timing was dialed in before troubleshooting any further.
Engine "shake" doesn't necessarily mean a reciprocating balance problem. You need to trouble shoot carb, distributor and spark plug wires. Good luck.
Regardless, if he returned the engine to you vibrating and "running bad", he is indeed a jabroni. Why don't you post up his name so other members in the area don't make the mistake of hiring him?
There is a difference between a "vibration" and maybe rough running because soimething is not timed properly etc. Does the "vibration" get worse as you slowly rev the engine hiigher ?
Yes, please post the name of the person/place that did the engine work. There are not many engine/resto shops in the greater StL area that claim to know much about Oldsmobiles. I'd like to be able.to steer clear of this guy/place should I ever need anything.
This, it could be a lot of things causing a misfire that could make you think it's an engine vibration.
joe_padavano
October 15th, 2016 09:51 PM
StarGeneral
September 18th, 2012 10:56 AM
