Std volume or high volume oil pump?
Old April 6th, 2024, 01:32 PM
PaulWinn's Avatar
Assembling by 455 this week finally
Previous owner had a Melling hv oil pump combined with a Moroso aftermarket 6 qt oil pan. I am going back with stock oil pan. Will the hv pump suck my oil pan dry? And it might be pertinent that my main bearing clearances are on the high side .0028 average.
PaulWinn is offline
Old April 6th, 2024, 03:16 PM
cutlassefi's Avatar
.0028 is NOT on the high side. I run .0032-.0035 on the mains 1-4 with no issues. You should be fine with an hv pump.
cutlassefi is offline
Old April 6th, 2024, 03:23 PM
The "suck the pan dry" myth is another that refuses to die.
joe_padavano is offline
Old April 6th, 2024, 06:13 PM
Andy's Avatar
Amazing how rumors on oil issues in Olds refuse to die..95% of classic car owners rarely hit 5500 rpm.
Andy is offline
Old April 6th, 2024, 06:14 PM
Yup. And they MUST have four wheel disc brakes and rack and pinion steering and tubular control arms to drive the car to cruise night and back once a week.
Old April 6th, 2024, 06:15 PM
PaulWinn's Avatar
Sorry! It's my first BBO build, motor is so hard to get in and out I'd hate to do it twice
PaulWinn is offline
Old April 6th, 2024, 06:44 PM
Hey, I’m in the 5% club!
Fun71 is offline
Old April 7th, 2024, 04:47 AM
Same here.
Old April 7th, 2024, 10:12 AM
With TH400, 3.42's, and 235/60/15's, my '67 is turning 3,100 RPMs at 70mph and it sounds like I'm inside a Rocket Ship (pun intended)! I can't even imagine running it at 5,000 RPMs!
Dream67Olds442 is online now
Old April 7th, 2024, 11:16 AM
Andy's Avatar
Both my cars are four speeds and I run through the gears quite often shifting at 5500. That’s what they’re built for. That’s what I like to do.
Andy is offline
Old April 7th, 2024, 10:34 PM
Pedal to the floor should result in a 1-2 shift at around 5000 RPM. Have you never done that?
Fun71 is offline
Old April 8th, 2024, 06:18 AM
Proud Viet Nam Veteran
redoldsman's Avatar
You probably can't do that in a Cutlass Supreme since you can't get headers that fit. Just kidding. Another one of those old rumors.
redoldsman is offline
Old April 8th, 2024, 06:41 AM
Kenneth - Yes I have, but less than a half dozen times. I have never had the car on a track or open lot where I felt like I could open it up and take my attention away from my driving to watch the Tach at the 1st shift point. When the hard shift occurs from 1st to 2nd the car gets real squirrelly because the tires start spinning so much faster it's all I can do to keep her going straight. As I told Andy in a PM yesterday, the shift point is probably close to or even above 5,000 RPM's, I just don't know.
Old April 8th, 2024, 07:29 AM
herkguy's Avatar
My HV pump came with two springs for the relief, one is for higher pressure which I installed.
it puts out 75-80 psi cold. It keeps me from getting on it until it’s warmed up though as a benefit…
I know some have just drilled a new hole for the retaining pin to increase spring pleasure also.
honestly I likely could have just used the regular one, but I am not disappointed in it’s pressure.
you likely will have good pressure with your clearance.
Maybe Mark would have some thoughts on the pressure springs.
herkguy is offline
Old April 8th, 2024, 02:02 PM
Bernhard's Avatar
Nice!
Bernhard is offline
dieselolds81
October 31st, 2023 11:29 AM
jskorz
October 9th, 2021 12:55 PM
Cdub
July 2nd, 2016 06:29 AM
71cutlasssx
November 11th, 2009 05:16 AM
68conv455
December 26th, 2007 07:29 AM
Quick Reply: Std volume or high volume oil pump?
