Is There a Head Thickness Specification?
Old March 24th, 2012, 06:46 PM
When I warped my BMW head, there was a factory spec for the thickness from the valve cover gasket surface to the head gasket surface - I wasn't supposed to deck it more than that number or Bad Things would happen.
I have not seen a similar spec for Olds heads.
Is there any valve gasket to head gasket surface spec that I should be aware of?
I ask because I have a set of B heads I might be decking a bit, but someone already machined some amount off of them - if I had a spec, I could tell how much, and whether I needed to take any more off. Without it, it's kinda guesswork.
I have already cc'd it (a bit inexpertly) and gotten roughly the specified volume (about 82 or 84cc if memory serves), so I believe they only cleaned up a few thousandths.
My intention, when I get a round tuit, is to remove roughly 0.030", which is the difference between the stock 0.016" steel shim head gasket and the run of the mill FelPro 0.046" gasket, thus maintaining proper geometry and orientation, as well as compression ratio (specified at 10¼, but from all I've heard, probably actually 9¾ or 10:1, which should be manageable on 93 octane and the right cam).
Thanks!
MDchanic is online now
Old March 24th, 2012, 06:54 PM
Chevy budget Olds powered
coppercutlass's Avatar
yes i dont have the book in front of me but i believe the btr and mondello book specify the correct thickness. The combustion chambers always vary a little from what i have been told.
coppercutlass is offline
Old March 24th, 2012, 07:14 PM
I'll check my Bill trovato book. I don't remember seeing it in there (and I did read it cover to cover ).
Old March 24th, 2012, 07:46 PM
If not i will find it in know it's gotta be in one of those books i have read both and overtime they kinda meshed togetehr lol. If no one chimes in i will find it and post.
Old March 24th, 2012, 10:40 PM
70Post's Avatar
The Mondello Olds V8 Technical Reference Manual says you measure "the distance between the head bolt boss and the deck surface of the head" (pic shows a dial caliper measuring this). Book continues....."If this dimension is less than 2.200", then most likely the surface of that head has already been milled at some point. The average stock measurement for an OEM head is 2.200" - 2.220"
70Post is offline
Old March 25th, 2012, 06:20 AM
So, with typical GM precision, there's 0.020" tolerance in the spec.
Sounds like a reasonable tolerance, though, considering they were using hydraulic lifters, which can accommodate a 0.020" variation.
Thanks, Patton! ... And, yes, that's the book I don't have.
Old March 25th, 2012, 06:30 AM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
X2
Also in the Wild About Cars "Engine Modification and Tuning Guide". They mention heads shouldn't be milled more than .060
67Olds442X2 is offline
MDchanic
April 27th, 2014 05:50 PM
joepenoso
June 16th, 2013 07:12 AM
rustyroger
March 13th, 2013 12:02 PM
valhalla
May 30th, 2011 04:07 PM
hazzmatte
October 9th, 2010 12:15 PM
Quick Reply: Is There a Head Thickness Specification?
