FYI ARP head bolt torque specification different
Old June 12th, 2013, 11:06 AM
joepenoso's Avatar
Thumbs up FYI ARP head bolt torque specification different
FYI
Factory shop manual says to torque head bolts to 85 ft. lbs.
ARP bolt co. says to torque them to 70 ft. lbs.
Phoned ARP and they said to follow Olds tightening sequence but torque to 70.
joepenoso
joepenoso
joepenoso is offline
Old June 12th, 2013, 04:21 PM
BlackGold's Avatar
You should always follow the instructions of the manufacturer of the fasteners. The proper torque depends on the design and material of the fastener and on the lube you use (again, follow their instructions for lube).
BlackGold is offline
Old June 12th, 2013, 06:25 PM
Originally Posted by BlackGold
... follow their instructions for lube
Yes, ARP torques are for ARP lube ONLY.
MDchanic is offline
Old June 12th, 2013, 06:49 PM
TripDeuces's Avatar
Required torque specs actually go up on ARP bolts and studs if you use anything but their lube. EI: oil, moly, etc.
TripDeuces is offline
Old June 14th, 2013, 05:30 AM
joepenoso's Avatar
I used 70 ft. lbs. and their lube that came with the bolts.
joepenoso
Old June 16th, 2013, 07:12 AM
joepenoso's Avatar
On the other hand maybe I will up the torque................................
http://realoldspower.prophpbb.com/topic812.html
especially read the last 3 postings
joepenoso
RAMBOW
May 27th, 2017 06:11 AM
EightballZ
March 24th, 2014 05:03 PM
ohiocutlassparts
January 15th, 2014 04:36 PM
Al2011
April 18th, 2013 10:49 AM
MDchanic
March 25th, 2012 06:30 AM
Quick Reply: FYI ARP head bolt torque specification different
