Valve seal 394
Old July 31st, 2009, 02:35 AM
rs2600's Avatar
Valve seal 394
Can the valve seals easily be changed without removing the heads? Any special tools required?
Thanks,
Matt
rs2600 is offline
Old July 31st, 2009, 05:08 AM
Oldsdruid
rocketraider's Avatar
It can be done with heads on the engine.
You'll need a spark plug hole air chuck tool (and air compressor) to hold the valves shut while you're working so the valves don't drop into the cylinder.
You'll also need a lever-type valve spring compressor. You may be able to rent both tools from a parts store.
You'll have to remove the rocker shaft, then use the spring compressor to remove the valve keys and springs. Once those are out of the way, you can install the new valve seals. Valve adjustment is automatic on reassembly.
rocketraider is offline
Old July 31st, 2009, 06:45 AM
rs2600's Avatar
Thanks, just what I wanted to hear.
Matt
rs2600 is offline
and1stp
November 4th, 2023 07:42 AM
esisson
June 7th, 2023 07:44 AM
fv64olds98
February 11th, 2013 10:39 AM
trackz man
July 17th, 2011 10:08 PM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: Valve seal 394
