Valve train noise
Old November 29th, 2008, 09:40 AM
blawton442's Avatar
Valve train noise
I have a 1970 Oldmobile 442 with a 455 CID engine. It overheated on me a year ago and has since made a clacking noise that sounds like it is coming from the valve train. I have replaced the lifters and push rods and the noise seems to have decreased a little. I believe what happened when the engine over heated it loosened some gunk in the passages and now one or more are blocked and the lifters are not getting enough oil. I have run motor flush through a couple of times and I am driving once a week to get engine up to normal operating temperatures in the hope that it will clear the blocked passages. Any suggestions? Thanks.
blawton442 is offline
Old November 29th, 2008, 01:06 PM
Official Tire Kicker
Willidog's Avatar
Have you checked the lobes on the cam to make sure they are in specs?
Willidog is offline
Old November 29th, 2008, 03:29 PM
Past Administrator
Oldsguy's Avatar
If the engine has never been rebuilt you may have some worn rocker arms or even some burnt valves, they can cause noise too.
Oldsguy is offline
Old November 30th, 2008, 05:20 AM
blawton442's Avatar
thanks for both of your suggestions. I have not checked the cam lobes but I have changed the rocker arms. Another reason I believe the oil passages are blocked is after I changed the parts I left the valve covers off and very little oil was coming out of the push rods. just a dribble. after I used the engine cleaner a few had oil shooting out, which I am assuming is more normal. Again thanks for your suggestions.
fv64olds98
October 30th, 2012 09:28 AM
russell-t
October 8th, 2012 05:58 AM
ragtop70
September 3rd, 2012 10:15 AM
67Olds442X2
March 28th, 2012 05:31 PM
64oldsguy
July 2nd, 2011 08:40 AM
Quick Reply: Valve train noise
