Water Pump for 455?
GMB aluminum pump is what i use -- 5" shaft height. Available at advance auto for a lot less than summitt. GMB part number 130-1260AL.
Heres one for cheap:
http://www.partsgeek.com/wxs77f8-old...ile+Water+Pump
And another link --
http://autoplicity.com/3732598-gmb-n...rCEaAucQ8P8HAQ
Well -- i guess youre on your own -- here is a chart that lists all 3 different lengths being a use on 1971 350 engines. Actually i have not been able to fine the exact shaft length for the 130-1260 today - so you need to verify it is the one that will match your pulleys.
i actually i am using a pulley set off a 73 350 on this pump on my 400 in a 67.
http://www.oldsmobility.com/oldsmo/v....php?f=6&t=391
Nor Cal Andy
March 29th, 2012 07:27 PM
