Windage tray and hardware
Old February 2nd, 2024, 05:14 AM
Chuck22's Avatar
Everyone fans of Mildon Windage trays? I do have the factory Toro tray. One better then other? If I go with the larger mildon can I use arp studs or do I have to buy the mildon hardware?
Chuck22 is offline
Old February 2nd, 2024, 06:51 PM
Bernhard's Avatar
The Toro one is not a windage tray but more like a baffle. The Toro pan does not have a baffle like the stock pan and the bolt in tray takes its place.
Bernhard is offline
Old February 2nd, 2024, 09:47 PM
70W-32's Avatar
You need a main bolt or stud with the seperate smaller stud on top. The Milodon tray is very effectve at controling crank windage
70W-32 is online now
Old March 24th, 2024, 12:54 PM
Chuck22's Avatar
are both of these baffles specific to the toro motor and toro pan combo? They don’t fit w the ARP mains .
Chuck22 is offline
Old March 24th, 2024, 05:02 PM
Bernhard's Avatar
Those are Tornado pan specific and are designed to work with the factory hardware and pan.
Bernhard is offline
Old March 24th, 2024, 05:25 PM
Chuck22's Avatar
Thanks!
are both of these
Chuck22 is offline
Old March 31st, 2024, 10:12 PM
Do Damage
67CSConvert455's Avatar
I was using the Toronado oil pan with the rear baffle. Then installed ARP main studs and went to stock oil pan because they hit the Toro pan hump.
67CSConvert455 is offline
Old April 1st, 2024, 07:23 AM
Run to Rund's Avatar
For 0over 50 years racers etc. have used a rosebud torch to flatten that hump in the Toro pan which is there to clear the front drive axle. Oil drain back is significantly improved, and that was the main deficiency to using the Toro pan for performance. Of course, adding baffles to the front and rear of the sump is a good idea too.
Run to Rund is offline
Old April 4th, 2024, 01:11 PM
Do Damage
[QUOTE=Run to Rund;1562213]For 0over 50 years racers etc. have used a rosebud torch to flatten that hump in the Toro pan which is there to clear the front drive axle. Oil drain back is significantly improved, and that was the main deficiency to using the Toro pan for performance. Of course, adding baffles to the front and rear of the sump is a good idea too.[/QUOTE
I should try that Run to Rund. I’d be nice to have the extra quart the Toro pan provides.
Bernhard
March 31st, 2024 10:05 PM
tricordati
August 14th, 2023 12:20 PM
biggus
January 28th, 2015 05:55 PM
steverw
December 31st, 2014 02:22 PM
68rocketred
April 10th, 2008 11:39 AM
Quick Reply: Windage tray and hardware
