Yikes!
Old April 18th, 2024, 01:34 PM
72455's Avatar
Yikes!
How does this happen?? (Luckily I had a spare in the garage).
72455 is online now
Old April 18th, 2024, 01:39 PM
Oooops. Misalignment, too loose or incorrect belt for application.
Vintage Chief is online now
Old April 18th, 2024, 01:40 PM
v8al's Avatar
One problem is that your belts are on wrong. The alternator belt goes on first (closest to the water pump) and then the power steering belt goes on.
You could also have the wrong water pump pulley.
v8al is online now
Old April 18th, 2024, 01:51 PM
72455's Avatar
Can anyone confirm this please? It would explain a lot.
72455 is online now
Old April 18th, 2024, 02:01 PM
69455's Avatar
If not any of above brkt could be flexing
69455 is offline
Old April 18th, 2024, 02:04 PM
I would think you could rapidly confirm via the CSM.
72455's Avatar
This has never happened before, so I don't think it's the water pump pulley.
72455 is online now
Old April 18th, 2024, 02:05 PM
72455's Avatar
Misalignment caused by the belts being on wrong?
72455 is online now
Old April 18th, 2024, 02:11 PM
Who knows. Incorrect spacers on brackets, incorrect brackets, spacers installed incorrectly on brackets, brackets installed incorrectly yielding to belt misalignment. It's rather well described in the CSM and the PIM.
Old April 18th, 2024, 02:19 PM
Old April 18th, 2024, 02:49 PM
72455's Avatar
Well, looks like I've got something else to work on...lol.
Now, if I could get some guidance on this, I'd be even further ahead.
https://classicoldsmobile.com/forums...squeal-178810/
72455 is online now
Old April 18th, 2024, 03:46 PM
v8al's Avatar
v8al is online now
Old April 18th, 2024, 03:57 PM
Belt misalignment as said above. I had that happen back in the 80s after an alternator replacement. Discovered there was a washer UNDER the pulley instead of ON TOP of the pulley. That was enough misalignment to cause the belt to roll at high RPM. Apparently it doesn’t take much misalignment to cause an issue.
Fun71 is offline
Old April 19th, 2024, 03:39 AM
72455's Avatar
Refresh my memory...two nuts to loosen for removal of the p/s belt. One up top and one down below, correct?
72455 is online now
Old April 19th, 2024, 04:12 AM
Muggard's Avatar
Two bolts on the front side (one up top and one near the bottom). There is also a nut on the rear bottom side. Loosen all 3.
Muggard is offline
Old April 19th, 2024, 04:06 PM
72455's Avatar
What's the trick to getting to the bottom bolt? It's pretty tight quarters down there, and I know I've done it before, but memory fails me...lol
72455 is online now
Old April 19th, 2024, 04:54 PM
Muggard's Avatar
I use an open ended wrench. Tough to get a good bite on the bolt, so hopefully, you can break it loose farily easily.
Muggard is offline
Old April 19th, 2024, 05:05 PM
72455's Avatar
I tried that but there's no way to get a swing once I grab the bolt.
72455 is online now
Old April 19th, 2024, 06:16 PM
72455's Avatar
Can someone please provide a pic? I'm in a time crunch.
72455 is online now
Old April 20th, 2024, 02:46 AM
72455's Avatar
This is really frustrating me because I know I've done it before but I can't remember how. I've got to be overthinking it or I'm missing something. I know it wasn't this difficult for me the last time.
72455 is online now
Old April 20th, 2024, 09:35 AM
Tedd Thompson's Avatar
Try a ratchet end wrench, you maybe get a click or to with that...Tedd
Tedd Thompson is offline
Old April 20th, 2024, 09:39 AM
72455's Avatar
Yup...that's my plan. I just wish I could remember how I did it last time. Do you think an offset box wrench would work?
72455 is online now
Old April 20th, 2024, 10:30 AM
Can't recall exactly how I removed/re-installed that bolt but I'm nearly positive it was a swivel socket on a ratchet or a swivel adapter attached to a socket. Maybe an offset - don't recall. I have a set of 1/4" sockets & 1/4" ratchet wrench which has bailed me out in many instances. 1/4" sockets, swivels & ratchets are awesomely handy in tight spaces.
Old April 20th, 2024, 10:39 AM
72455's Avatar
Norm, do you think 1/4" drive would give me enough leverage?
72455 is online now
Old April 20th, 2024, 11:02 AM
Dave - Removing that bolt isn't something I've ever routinely had to do. Wish I could answer that for you. Sometimes it's a combination of things including a small extensions & small hollow pieces of metal (pipe) over the wrench/ratchet. Think outside the box. Sorry, buddy. You'd be surprised the amount of force/leverage 1/4" ratchets, sockets provide.
Old April 20th, 2024, 06:17 PM
72455's Avatar
Now I remember what I did...I used the right size wrench...lol. Went back at it tonight after work and realized I was trying to turn a 1/2" bolt with a 9/16" wrench...Doh! Things went great once I figured that out...lol.
72455 is online now
Old April 21st, 2024, 11:41 AM
herkguy's Avatar
Hehe….
herkguy is offline
Old April 21st, 2024, 12:01 PM
Old April 21st, 2024, 01:29 PM
72455's Avatar
Yep Norm...a lesson well learned...lol. I bet I wont forget again.
72455 is online now
Old April 21st, 2024, 01:36 PM
Dave - Your most admirable quality is your honesty. Not many would even admit to having made this error. I hope you get the belt issue resolved.
Old April 21st, 2024, 01:39 PM
  #31
72455's Avatar
I already did Norm...switched them around last night. And I don't mind admitting my blunders...so much the better if others can benefit.
72455 is online now
Old April 21st, 2024, 01:44 PM
  #32
Yeah, I recall me installing the oil pan gasket on my 350 twice and admitting how far too much gasket sealer I had used. That was painful especially while working under the car on jack stands w/ engine hoisted just enough (4") to get the oil pan free.
tkcutlass
September 20th, 2023 08:09 PM
Rallye469
August 21st, 2023 05:12 AM
tkcutlass
October 18th, 2022 09:38 PM
Supernice88
September 21st, 2022 04:52 AM
tkcutlass
April 3rd, 2022 07:52 AM
Quick Reply: Yikes!
