Olds 400 and 403. The same?
Old February 8th, 2015, 11:20 AM
Chris289's Avatar
Hey people, I've been contacted about rebuilding an Olds 400 V8 for a customer. Trying to gather a price guide together, summit don't list much in terms of an engine rebuild kit for the 400 but they list a kit for the 403 which includes all new gaskets, rings and bearings. Just a quick question, will the 403 parts work with the 400? They are both classed as the 6.6 litre engine.
They do list a gasket kit for the 400 which is the same kit I just used on a 455 engine but it's the rings I need that they don't list for the engine directly.
Any help would be appreciated.
Many thanks,
Chris.
Chris289 is offline
Old February 8th, 2015, 11:27 AM
Justin
oldstata's Avatar
400 is a big block
403 is small block
Most gaskets are the same for the Bbo / SBO
Not sure on what interchanges with internals. I am sure some one with better knowledge will chime in
oldstata is offline
Old February 8th, 2015, 11:38 AM
Chris289's Avatar
Ah ok I thought they were both big blocks. How about the piston rings though? Will the 403 fit the 400 engine?
Chris289 is offline
Old February 8th, 2015, 11:41 AM
oldsmobiledave's Avatar
fyi
No. The bores are vastly different.
oldsmobiledave is offline
Old February 8th, 2015, 11:43 AM
FYI, there are two different 400 Olds engines:early (1965-1967) and late (1968-1969).
To answer your question, no, the 403 has a bore diameter of 4.351" whereas the early 400 (65-67) has a bore of 4.000" and the late 400 (68-69) has a bore of 3.875".
In order to determine which engine block you have, check the casting number on the shelf above the water pump, post it here, and someone will tell you which one it is.
Fun71 is online now
Old February 8th, 2015, 11:47 AM
Chris289's Avatar
The car is a 69 442. I can only assume the engine is a 69 engine without seeing it in person.
Chris289 is offline
Old February 8th, 2015, 11:55 AM
2blu442's Avatar
If you need the customer to identify it for you here's an old thread with photos of where to look. The early 400 would have a large letter E at the end of the casting numbers between the water pump and intake. The late one would be a G which would be correct if it has the original engine. John
https://classicoldsmobile.com/forums...s-engines.html
2blu442 is offline
Old February 8th, 2015, 12:07 PM
There is also a B code for the 65 400 engine.
Fun71 is online now
Old February 8th, 2015, 12:21 PM
2blu442's Avatar
Oops! I keep forgetting about the B block. 1965 442 only but they are out there.
2blu442 is offline
Old February 8th, 2015, 12:22 PM
Justin
oldstata's Avatar
Lol didn't any one click on your link john the first pic shows a b block lol
oldstata is offline
Old February 8th, 2015, 12:25 PM
2blu442's Avatar
Ah... but that's the 3B on a 1977 350 engine. Yes, sometimes life isn't always as simple as we think.
2blu442 is offline
Old February 8th, 2015, 12:28 PM
Justin
oldstata's Avatar
Oops ... Know look who needs to read and stop half fast glancing at pics lol
oldstata is offline
Old February 8th, 2015, 12:31 PM
2blu442's Avatar
OK, maybe I need to add this to the old thread. But here's the letter B and casting number for the 1965 400
2blu442 is offline
Old February 8th, 2015, 01:01 PM
Octania's Avatar
Before ordering parts you would do well to find out exactly what casting the block is.
400G the same as 400E the same as 400B the same as 403?
Well, except the pistons, rings, block, crank, rods, head gasket, intake, heads, timing set, lifters, and exhaust manifolds, yeah, pretty much the same.
If you are replacing or buying any of those parts then you need to be precisely specific on the casting numbers involved, therefore which engine it is.
'69 442 should be the small bore long stroke G-400 big block with C heads, J intake, and W-Z exhaust manifolds. Lifters may be the larger .921" - I can't remember.
Octania is offline
Old February 8th, 2015, 10:14 PM
No, the lifters wold be the typical .842" diameter. I think the '67 engines were the last ones to use the .921s.
Fun71 is online now
Old February 8th, 2015, 10:58 PM
Chris289's Avatar
Cool, thanks for all the info guys, good to learn new things. What I'll do is give him a "rough" price on the parts and then tell him that when the time comes we will have to identify the engine correctly to order the parts.
Thanks for all the help,
Chris.
Chris289 is offline
Old February 9th, 2015, 10:54 PM
64Rocket's Avatar
If it is a "G" block, you are going to have some trouble finding pistons. Cast piston may be your only choice. Also if it is a "B" or "E" block, pistons will also be cast.
Gene
64Rocket is offline
Old February 10th, 2015, 12:17 PM
Finding off-the-shelf pistons may be an issue, but getting them custom made will be simple. Almost all of the main piston manufacturers will make them to your specifications. Cutlassefi just mentioned a set of custom pistons for around $650 shipped.
Fun71 is online now
aussiemobile
February 15th, 2013 07:31 AM
beerdeadladies
September 4th, 2010 07:21 PM
RAMBOW
April 1st, 2010 06:39 PM
slumpy
July 29th, 2009 11:28 AM
jeffreyalman
June 6th, 2009 06:28 PM
Quick Reply: Olds 400 and 403. The same?
