70 cutlass Tooth Angle
Hi, I'm in the process of installing a OEM tooth on an after market hood on my 70 cutlass. While the holes & edges match up well, the tooth seems to be bent inward a bit too much (rubbing on the grills). after lookings at many 70 cutlass pics on the internet i noticed many tooths seem bent inward, and i dont remember how my original tooth was appeared.
Question i have is, should the tooth be 90degrees perpendicular to the ground or should it have a slight bend inward at the bottom? if bent in, how much?
Thanks,
Ed
Thanks,
Ed
The "tooth" needs to be at whatever angle it takes to NOT rub on the grills. I suspect that is 90 degrees perpendicular to the ground...or possibly perpendicular to the flat "plane" of the top of the hood.
I'm assuming that your hood positioning/fitment is "good" re: front edge of hood to front edge of fenders and same on rear of hood to rear of fenders.
Thanks, yes the hood & hood gaps are all aligned. i put on the OEM hockey sticks to help align and it does seem to have a natural bend inward at the bottom. I wasnt sure if this was due to some previous damage or if this was by design. i can try and pull it out a bit but 90deg (yes perpendicular to the ground) seems to put too much stress on the tooth/hood connecting points.
Ed
Ed
