70 cutlass Tooth Angle
Old February 7th, 2024, 08:39 AM
70ish's Avatar
Hi, I'm in the process of installing a OEM tooth on an after market hood on my 70 cutlass. While the holes & edges match up well, the tooth seems to be bent inward a bit too much (rubbing on the grills). after lookings at many 70 cutlass pics on the internet i noticed many tooths seem bent inward, and i dont remember how my original tooth was appeared.
Question i have is, should the tooth be 90degrees perpendicular to the ground or should it have a slight bend inward at the bottom? if bent in, how much?
Thanks,
Ed
70ish is offline
Old February 7th, 2024, 10:56 AM
70Post's Avatar
The "tooth" needs to be at whatever angle it takes to NOT rub on the grills. I suspect that is 90 degrees perpendicular to the ground...or possibly perpendicular to the flat "plane" of the top of the hood.
I'm assuming that your hood positioning/fitment is "good" re: front edge of hood to front edge of fenders and same on rear of hood to rear of fenders.
70Post is offline
Old February 7th, 2024, 01:37 PM
70ish's Avatar
Thanks, yes the hood & hood gaps are all aligned. i put on the OEM hockey sticks to help align and it does seem to have a natural bend inward at the bottom. I wasnt sure if this was due to some previous damage or if this was by design. i can try and pull it out a bit but 90deg (yes perpendicular to the ground) seems to put too much stress on the tooth/hood connecting points.
Ed
70ish is offline
Old February 7th, 2024, 03:10 PM
Gary
VC455's Avatar
Originally Posted by 70ish
... 90deg ... seems to put too much stress on the tooth/hood connecting points.
I found the same. So I bent the hood attachment as far as I felt safe with and completed the 90° alignment by shimming the tooth/hood connection.
VC455 is offline
rhaberm
June 1st, 2023 11:31 AM
rhaberm
July 24th, 2020 04:22 PM
Bitburger
February 27th, 2016 02:06 PM
Bitburger
February 15th, 2016 11:21 AM
Slater442
May 19th, 2012 07:39 AM
Quick Reply: 70 cutlass Tooth Angle
