applying W30 stencils?
Old September 1st, 2012, 04:59 AM
matviar's Avatar
My brother just painted my 70 442 convertible and the paint looks great. I tried to put on one of the hood stencils from the parts place and ruined it. Once it sticks, you cant correct for mis alignment. Is there any product out there for floating the stencil around to get it positioned ? This type of stencil uses 3 M backing. You pull the paper backing off, apply the stencil, then pull the top paper off to expose the tape. Any advice would be greatfully appreciated!
matviar is offline
Old September 1st, 2012, 08:03 AM
Shoveling Snow
Hairy Olds's Avatar
Use a solution of a couple of drops of dish soap to a gallon of water. Use a spray bottle to apply to the paint and run your hand over the solution to get rid of the bubbles. Use a squeegee to push the solution out from under the stencil. Let the stencil dry for a little while before removing the transfer paper.
Hairy Olds is offline
Old September 2nd, 2012, 03:09 AM
matviar's Avatar
Somebody I know mentioned soap water. I was afraid the soap water would damage the adhesion of the tape to the body. Have you ever tried this? Thanks!
matviar is offline
Old September 2nd, 2012, 01:28 PM
Shoveling Snow
Hairy Olds's Avatar
The trick is to use just a couple of drops of dish soap to a gallon of water. I use this solution all the time when putting a mask on my glass when sandblasting and other decals. The trick is squeeging the water out without damaging the vinyl. Be gentle!
Old September 2nd, 2012, 05:05 PM
matviar's Avatar
I'll give it a try. THANKS!!!
matviar is offline
Old September 4th, 2012, 06:17 AM
stevengerard's Avatar
these stencil kits work great for the hood but you will have to play with them or even customize them to get them to work proerly around the wheel wells,
stevengerard is offline
Old September 4th, 2012, 09:28 AM
72 Olds CS
RetroRanger's Avatar
windex works good too for aligning decals and emblems and squeeging out bubbles etc
RetroRanger is offline
jstrits
December 4th, 2016 06:48 PM
70-442-W30
July 30th, 2016 04:27 PM
jstrits
February 11th, 2015 04:30 AM
oldsca
June 14th, 2010 05:46 AM
Doug69Cutlass
May 7th, 2009 06:56 PM
Quick Reply: applying W30 stencils?
