Question on Prep for Applying a Sticker?
Old May 7th, 2009, 03:34 PM
Member
Doug69Cutlass's Avatar
I bought a GM Mark of Excellence sticker to go in the door jamb. I know the surface has been waxed in the past. What is good to remove the wax before applying the sticker? I was thinking about using alcohol or mineral spirits. Would those do the trick?
Doug69Cutlass is offline
Old May 7th, 2009, 04:05 PM
Registered
Bluevista's Avatar
They give you alcohol soaked pads to remove the wax before you stick on accessory things so I guess that would do it.
Bluevista is offline
Old May 7th, 2009, 04:07 PM
jensenracing77's Avatar
i used alcohol and was good. i also used a heat gun and made the area warm to the touch before applying the sticker.
jensenracing77 is offline
Old May 7th, 2009, 06:56 PM
Member
Thanks, I've got a bottle of alcohol and that sounds like a good way to go.
amoman82
April 9th, 2017 07:18 PM
72notchback
Body work
17
August 24th, 2014 02:41 PM
matviar
September 4th, 2012 09:28 AM
nonhog
September 1st, 2010 08:44 AM
oldsca
June 14th, 2010 05:46 AM
Quick Reply: Question on Prep for Applying a Sticker?
