Bonding the hood frame to the hood sheet metal
Old February 20th, 2024, 10:07 AM
Rob64cutlass's Avatar
Some of the areas on my hood have let go from the factory glob of whatever bonding agent they used.... From what I've read 3M NVH is what I need to be using. There seems to be a few different kinds, what is the difference between dampening material, Flexible foam and pillar foam. And which do I need to bond the areas back? Also, do I need to try to remove the old or should I just fill in the gap where the original let go? Definitely don't want a wavy hood. Any advice or Tricks to keep the hood nice and smooth would be greatly appreciated
Rob64cutlass is offline
Old February 20th, 2024, 12:27 PM
Rodney
cdrod's Avatar
I've had good results with a product called Sikaflex 252. It bonds well to many substrates (including metal), has good adhesion and is flexible enough to resist breaking when subjected to vibration and lateral loading.
Rodney
cdrod is offline
Old February 20th, 2024, 04:14 PM
Rodney
MyBlue72
February 4th, 2018 03:44 PM
gbledsoe3
Body work
19
November 9th, 2016 10:53 AM
455man
Body work
March 27th, 2013 02:07 PM
rodan
December 27th, 2010 07:35 PM
Quick Reply: Bonding the hood frame to the hood sheet metal
