Vista Cruiser Replacement Door Seals
Hi All, in addition to the tailgate sash issues I just posted about, I've decided to replace the door seals. The front ones are definitely shot and I might as well do the back too. There are plenty of good posts on this site on the subject, and as the preferred maker seems to Steele Rubber, I will go with them. However I do have a couple of other questions.
1) Do the both front and rear seals fasten with pegs? The pics and description for the Steele website show and mention these pegs for the rear seal, but not the fronts. On the other hand the Metro website shows both front and rear door seals with fitted pegs.
2) My car has additional rubber strips on the inside of the A pillars (picture below). I don't see replacements listed on the Metro or Steele sites - were these original equipment?
Thanks! Robert
Thanks! Robert
Thanks Tom! I was able to speak to Steele today and they confirmed that their front seals do actually come with pins (which can be seen on the site pics, but only if you zoom in.
The front pillar seals are just straight strips so I guess can be replicated easily by cutting new seals once I locate a compatible replacement strip. Still there are a lot of A Bodies out there so surprising someone hasn't plugged the gap! (So to speak)
Robert
Robert
Interesting that they were deemed necessary on Vista Cruisers but not used on Cutlasses. The door seals on my Vista are really old and messed up and the previous owner applied some generic black foam door seal on those areas, the wind noise is very loud and I figured new seals all around would fix the problem but I will not be aware to get those repalced as well.
Thanks all, very interesting and a bit of a mystery. My Assembly Manual doesn't have a section on interior trim (other than the dash), and reference pictures of pillared cars are relatively rare on Hemmings etc. I have seen pics for a few 2 door pillared coupes and they don't appear to have those strips. My strips are not screwed in - it looks as if they are retained by the A pillar trim. Close up below! Robert
