Rear Side trim on '72 98
Old October 25th, 2023, 10:30 AM
jpilk99's Avatar
Hi folks,
I think someone commented on this before, but, I'm curious - if I want/need to remove the rear side trim in the middle (vertically) of the car, see image, how to I get it off? It looks like I'd need to remove the interior rear seat armrest/side panel to access at nut/screw? The rest of it would be GENTLY pried off, releasing the top then bottom. Same I assume for the driver's door trim?
Thank you!!!!
jpilk99 is offline
Old October 25th, 2023, 12:00 PM
There should be studs that go through into the trunk and are secured with pressed tin nuts; as well as, snap on fasteners that are gently pried off. Remove the pressed tin nuts before prying.
Olds64 is offline
Old October 25th, 2023, 01:15 PM
jpilk99's Avatar
Thank you. I can see one "stud" at far rear of the vehicle and removed the nut. I haven't seen any other studs on the inside of the trunk - and that's why I'm wondering if the "forward" stud is resting behind the interior rear seat panel by the window? I'd rather not remove everything in the back seat only to find it's NOT there :-). I may just leave the trim where it is, unless anyone has ...pictures or videos of how to remove the trim. I'm hesitant to "gently pry them off" as I've not done it before and don't want to muck it up.
Thank you,
Jay
jpilk99 is offline
Old October 25th, 2023, 06:11 PM
Oldsdruid
rocketraider's Avatar
Let me get back home and I'll see what the 73 FBM says. I think those cars have a weld stud on the quarter and plastic "bathtub" moulding clips slide onto those. Then the moulding snaps onto the plastic clip.
There should be a stud and retainer on the front and rear edges of the doors. Remove those, then use a plastic pry bar to pop the moulding off the plastic clips.
The front fender spear mouldings are attached with studs and tinnerman nuts. PITA. You have to either remove the fenderwells or pry the bottom edge of the fender away from the car.
Rocker mouldings have screws under the bottom lip. Remove all those, then pull out the bottom lip and lift the moulding up and off the retainer clips.
rocketraider is offline
Old October 25th, 2023, 09:47 PM
Oldsdruid
Pictures of Ninety Eight mouldings and attachment methods.
The number is the Fisher designation for what the moulding is; i.e. 157 is a rear quarter panel upper, 80 and 100 are door upper mouldings, 173 is rocker moulding.
The letter shows attachment method. G is plastic clip and weld stud, M is a screwed-on t-nut clip, and so on.
Old October 26th, 2023, 09:01 AM
jpilk99's Avatar
Thanks Rocket Raider. Sorry if I'm a complete dolt here, but the Fisher Body manual doesn't say how to get the trim off those "G" mouldings. I'm thinking I should be able to slide them off, and then take the actual plastic molding holder itself off. Prying could/should work, but it doesn't seem like it wants to let go - and if I force it, I likely ruin it. Argh
jpilk99 is offline
Old October 26th, 2023, 09:39 AM
Oldsdruid
Sometimes they're tough to pry off, and sometimes a 50 year old plastic clip will break. Most good parts stores will have the "bathtub" trim clips or you can get them online. www.auveco.com or body shop supply stores often stock Au-Ve-Co parts.
Go to Harbor Freight, or sometimes a chain parts store has them, and get a set of these.
They have wide blades to spread the prying force over a larger area. Closer you can get to the actual plastic clip, the easier it will pry off.
Old October 26th, 2023, 10:52 AM
jpilk99's Avatar
Thanks so much
jpilk99 is offline
Old October 26th, 2023, 01:01 PM
jpilk99's Avatar
GOT THE DOOR TRIM OFF!!!! Thanks again!!!
jpilk99 is offline
Old October 26th, 2023, 02:16 PM
jpilk99's Avatar
And the rear trim!!!!! I’m a BIG BOY now!!!!!
jpilk99 is offline
Old November 10th, 2023, 04:52 AM
jpilk99's Avatar
Thank you all for your help. I think my driveway-rust work came out decent?
jpilk99 is offline
Old November 11th, 2023, 01:39 PM
Nutmeg 72 Olds 98's Avatar
Nice job the finished picture looks really good.
E
Nutmeg 72 Olds 98 is offline
jpilk99
September 26th, 2023 07:37 PM
klleetrucking
Body work
November 12th, 2020 02:42 PM
MMoney
Body work
May 30th, 2020 01:22 PM
Willyb
December 28th, 2014 09:07 PM
Napoleon Solo
June 20th, 2014 08:19 PM
Quick Reply: Rear Side trim on '72 98
