1987 delta 88 rear brake question?!
Old April 7th, 2009, 03:44 PM
WiSeGuY's Avatar
ya i got 87 delta 88 royal brougham
has drums in rear and i was wondering if there was a conversion kit to put discs instead of the drums? Or if a newer/older olds setup would work in the drums place?
WiSeGuY is offline
Old April 7th, 2009, 06:39 PM
Disk brake kits???? HaHaHaHa...
This car is not exactly mainstream. I would be absolutely amazed if there were a kit available. On the other hand, thanks to GM's parts-bin engineering, you are in luck. Your H-body shares rear wheel hubs with the 1986-1991 Cadillac Seville. The Sevilles were offered with four wheel disk brakes, so you can grab a set of those (along with the master cylinder and proportioning valve) and bolt them to your Olds. The only wrinkle may be if your car has ABS.
joe_padavano is offline
delmontcrusier
May 28th, 2023 07:37 AM
Kilmster
Brakes/Hydraulic Systems
August 6th, 2014 05:41 PM
zk194
October 11th, 2013 11:10 PM
Ndn_GivR
May 16th, 2008 08:33 AM
olds87
April 24th, 2007 01:59 PM
Quick Reply: 1987 delta 88 rear brake question?!
