66 toronado brake conversion?
Remove the old parts, install the new ones. The master cylinder must be changed to a disc/drum master cylinder. Drum/drum cars do not have a proportioning valve, so yes, one must be added. If your stock brakes are single circuit, you will probably need a 1967-up booster or you will need to shorten the pushrod between the booster and the master cylinder.
Mocephus
October 1st, 2021 09:45 AM
bluecab
August 6th, 2015 08:38 AM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
bluecab
November 2nd, 2011 12:22 PM
elcaminodave
August 9th, 2009 04:57 PM
