Disc Brake Conversion - Brake Line Change ?
Old June 25th, 2013, 06:24 PM
Dr.Olds Illegitimate Son
Maverick's Avatar
I converting my 1971 Cutlass Supreme convertible from power drums up front to power discs .
Do I need to replace my front brake line if they are fine ? I was told by another club member that they need to have a larger I.D.
Maverick is offline
Old June 25th, 2013, 07:01 PM
Never heard of that one.
Far as I know you just have to change the hoses so they fit the calipers.
MDchanic is online now
Old June 25th, 2013, 07:04 PM
Maverick's Avatar
I have those. Didn't think I needed to change the hard lines.
Thanks.
Brent
Maverick is offline
Old June 26th, 2013, 02:21 AM
kitfoxdave's Avatar
there is a little bit of difference between the disc and drum lines... mostly to accommodate the proportioning valve versus the drum brake distribution block. Eddie Hansen used the distribution Block with a manual vale for the rear brakes, may want to check his thread.
kitfoxdave is offline
Old June 26th, 2013, 05:54 AM
brown7373's Avatar
The lines are different, as are the brackets that hold the lines where they attach to the rubber hoses. The hoses may be different too. The master cylinder also different. Some might say you can rebend or adapt them, but I wouldn't want the lines sticking out and not properly attached and protected on the frame and a arms.
brown7373 is offline
Old June 26th, 2013, 05:58 AM
His question was about the diameter of the lines, not the routing.
Old June 26th, 2013, 08:21 AM
The line diameters are the same (3/16" for the front brakes, 1/4" for the back). The routing is different, as are some of the flare nuts. GM used different thread sizes on the various lines so they could not be mis-connected on the assembly line. I have rebent the drum brake lines and used inverted flare adapters on disc conversions, though now that I have a flaring set, I just make up new lines with the correct fittings (or buy pre-bent stainless lines).
joe_padavano is offline
Mocephus
October 1st, 2021 09:45 AM
Del70
November 15th, 2013 02:24 PM
dre
Drivetrain/Differentials
August 31st, 2011 11:04 AM
MX442
Brakes/Hydraulic Systems
February 2nd, 2010 02:47 PM
Quick Reply: Disc Brake Conversion - Brake Line Change ?
