Bleeding brakes on 78 Delta 88
Old August 22nd, 2009, 06:28 AM
capot's Avatar
The brake pedal on my wife's 78 Delta 88 Royal has gone to the floor. I checked the master cylinder and it was low - do I fill both sides or just the front? Filled the front and pumped the brakes, still goes to floor so I'll attempt to bleed them this afternoon. Does anyone know what size wrench I need to use on the bleeder valves? Any other things I should check that may cause this:
Chris
capot is offline
Old August 22nd, 2009, 06:36 AM
citcapp's Avatar
Check aroung each wheel and look for fluid on the ground, maybe a blown wheel cylinder or seal went bad in the master cylinder, or blew a rubber hose at one of the wheels or the hose from the hard line to the rearend, Something caused this problem. Fix that firs then we can talk about bleeding.
citcapp is offline
Old August 22nd, 2009, 05:17 PM
capot's Avatar
Thanks, exactly what a friend suggested especially since there is rust in the master cylinder. He suggested to first purge the system then go from there.
Chris
capot is offline
Old August 24th, 2009, 06:58 AM
IF there is rust in the master cylinder I would do a complete overhaul. You might even want to replace the lines. Make sure you check the condition of your wheel cylinders.
Olds64 is online now
Old August 24th, 2009, 03:11 PM
capot's Avatar
Thanks, thats the plan. Just have to wait for it to get below 105 outside before I start on this, mid 90's would work just fine.
Chris
capot is offline
Old August 24th, 2009, 03:13 PM
Chris, I know what you mean. I really wanted to work on the Olds this afternoon but the 100+ degree weather has forced me inside.
Old August 24th, 2009, 03:42 PM
capot's Avatar
And, when you hit 60yrs it gets even harder.
capot is offline
MudEye
June 16th, 2017 10:39 AM
Seff
April 13th, 2012 06:06 PM
redoldsman
Brakes/Hydraulic Systems
June 8th, 2011 04:36 AM
Pfiffle
April 3rd, 2008 04:48 PM
Chumley
February 29th, 2008 09:16 AM
Quick Reply: Bleeding brakes on 78 Delta 88
