gravity bleeding
Old March 18th, 2008, 03:14 PM
Pfiffle's Avatar
gravity bleeding
Anyone try this and have any luck with this method?
Pfiffle is offline
Old March 18th, 2008, 08:04 PM
72EPCutlass's Avatar
Yep, works great!
72EPCutlass is offline
Old March 19th, 2008, 06:07 AM
ozoneblue's Avatar
I always use this method first,Leave cap off MC & keep it full
ozoneblue is offline
Old March 19th, 2008, 06:20 AM
74 Omega's Avatar
This may sound stupid, but could some one explain it? I usually have to get my 12 yr old son or wife (not telling her age) to help... you can guess the fun in that. LOL
Dave
74 Omega is offline
Old March 19th, 2008, 07:04 AM
Pfiffle's Avatar
No, it's not stupid 74Omega I just heard of this myself and it sounded like a good way of not having the wife come out and "help" me. We all know how that turns out sometimes. I googled it. I'm really not good at explaining things that I just found out about myself. Maybe some Olds Guru can enlighten both of us. Tom.
Pfiffle is offline
Old March 19th, 2008, 02:59 PM
Registered
Bluevista's Avatar
I use my Mityvac with the brake bleeder attachment, can do it by yourself and it's fast.
Allan
Bluevista is offline
Old March 19th, 2008, 03:19 PM
Pfiffle's Avatar
So vacuum or pressure bleeding is still probably a good idea anyway to really make sure the air bubbles and water-contaminated brake fluid is out? What fluid do you guys use? This is for a '76 Cutlass by the way. DOT 3,4,5?
Pfiffle is offline
Old March 19th, 2008, 05:18 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
dot 3
J-(Chicago) is offline
Old March 22nd, 2008, 07:49 AM
I never liked using the Mit-y-vac bleeders or the gravity bleeding method. It never seems to work as well as the old fashioned way. The only problem is that you need a buddy to help.
Olds64 is offline
Old March 22nd, 2008, 09:35 AM
My brother turned me on to this...take the cap off of the master cylinder, make sure it is full and stays that way and crack the bleeders (one or all depending on the mess you want to make) open and let it run...thats it. Then close them in any order.
Old March 22nd, 2008, 12:00 PM
Pfiffle's Avatar
Thanks for all replies. I think I'm going to gravity bleed, then vacuum to make sure. Since the car is on jack stands already as I'm changing the 2.41 open to a 3.73 posi. that was custom built for me by monzaz here.
Pfiffle is offline
Old April 3rd, 2008, 04:48 PM
442Harv's Avatar
I hook up small plastic hoses, and put the end in a small can, that way you have no mess.
442Harv is offline
capot
Brakes/Hydraulic Systems
August 24th, 2009 03:42 PM
Deputy442
September 5th, 2008 05:15 PM
Bluevista
May 21st, 2008 10:20 AM
projectheaven
May 15th, 2008 01:11 PM
Chumley
February 29th, 2008 09:16 AM
Quick Reply: gravity bleeding
