Disc brake conversion 69 a body G body
Old April 30th, 2008, 04:29 PM
mrstevek79's Avatar
Did anyone ever try to use G body spindles etc? They look like they would work, I pulled a set off a 87 didn't try them yet.
mrstevek79 is offline
Old May 10th, 2008, 10:02 AM
NO, NO, NO!!! GM used a different ball joint taper on the A/G body cars starting in 1973. The later spindles will physically bolt up, but the tapered stud on the ball joint will not seat properly in the spindle, leading to eventual failure. This is NOT SAFE.
Your choices are to either use a factory style 64-72 brake kit or to use adapter ball joints. These are the ball joints used for the B-body spindle swap. The 73-up upper ball joints bolt right to the earlier A-arms, but the later lower ball joints need to have the housing machined to fit in the older lower control arms.
joe_padavano is offline
Mocephus
October 1st, 2021 09:45 AM
crazycowboyny
April 29th, 2014 02:33 PM
Maverick
Brakes/Hydraulic Systems
June 26th, 2013 08:21 AM
smcurro
Suspension & Handling
May 22nd, 2010 11:54 AM
smcurro
December 8th, 2009 07:09 PM
Quick Reply: Disc brake conversion 69 a body G body
